Author Topic: td injection pump idle speed adjustment rod  (Read 3469 times)
January 22, 2014, 10:23:19 pm
ktzdsl
  • 73
« on: January 22, 2014, 10:23:19 pm »
I have a 91 td jetta with a td pump that has the idle speed boost system as shown in the VW GTI, Golf, Jetta Service Manual for years 1985-1992. In section 6, page 11, Fig 5-3, line item #2, it shows the manual adjustment rod connected to the cold start handle.
I found that my pump is missing the adjustment rod. The mechanism works, because I pulled out my cold start cable, started the vehicle and manually rotated the idle boost lever.
Bottom line, does anyone have the missing rod they would sell to me? Thanks. ken
DFW area Texas
1982 1.6L NA diesel pickup
Reply #1January 23, 2014, 05:02:52 am
bbob203
  • 1789
Re: td injection pump idle speed adjustment rod
« Reply #1 on: January 23, 2014, 05:02:52 am »
That sucks.. I almost lost mine I was adjusting my idle and ran out of screw and it the bottom spring and detent sleeve were lost. Make sure you get those two pieces. You will also want to adjust the yoke so there are more threads catching where that thing screws in down at the advance mechanism.
« Last Edit: January 24, 2014, 06:00:43 am by bbob203 »
92 Passat wagon M-TDi
03 Jetta wagon TDi
VE Timing tools for rent
Reply #2January 23, 2014, 03:55:03 pm
« Reply #2 on: January 23, 2014, 03:55:03 pm »
I have what you need if you don't find anything before March.
