Author Topic: WTB AAZ parts for ACME 1.9 TD Samurai swap  (Read 5556 times)
January 09, 2014, 01:34:59 pm
Spokerider
  • 195
« on: January 09, 2014, 01:34:59 pm »
For the 1.9TD AAZ swap into my Samurai......
Needing an oil filter relocation kit, sandwich adapter with thermostat.....something like from a Volvo or? I have the oil cooler but need the filter adapter, the sandwich adapter and filter mount.
Needing a glow plug relay and glow plug wiring harness for same.
Needing fuel filter water separator and fuel pump for priming fuel lines.
Needing a 26" vw Quantum rad with AC, the dual fans, wires / relay and shroud,.........just like the ACME 1.9 conversion rad kit. [ kind of a long shot, but maybe someone has this ACME kit ]
Needing ACME Rear Water Outlet Housing (with temp sensors for glow plug, Suzuki gauge, aftermarket gauge plug)
Needing ACME Header Pipe with Flex Coupler all Turbo Diesel
Reply #1January 09, 2014, 04:18:32 pm
Re: WTB AAZ parts for ACME 1.9 TD Samurai swap
« Reply #1 on: January 09, 2014, 04:18:32 pm »
I have a quantum oil filter housing that angles it back instead of down. 35.00 plus shipping. Let me know.
Reply #2January 09, 2014, 06:20:23 pm
sdubfid
  • 63
« Reply #2 on: January 09, 2014, 06:20:23 pm »
Sidekick sport 1.8 rad works good, I found a perfect hose setup to use with it too.
I'm running a racor filter/primer and manual glowplug setup individually wired.
I think a 1.8t Audi a4 will have the right oil filter bracket for aaz, I think 1.6 and 1.9 are different.
Reply #3January 09, 2014, 06:34:11 pm
« Reply #3 on: January 09, 2014, 06:34:11 pm »
1.6 and 1.9 are different. I need to read better. I read acme sammi swap and just thought 1.6
Reply #4January 10, 2014, 07:16:07 pm
Spokerider
  • 195
« Reply #4 on: January 10, 2014, 07:16:07 pm »
How well does the Sidekick sport 1.8 rad cool a 1.9, and does it fit a sami well?
Reply #5January 11, 2014, 09:13:23 am
CdnVWJunkie
  • 309
« Reply #5 on: January 11, 2014, 09:13:23 am »
PM sent.
Reply #6January 12, 2014, 08:50:33 am
Big Daddy Roth
  • 298
« Reply #6 on: January 12, 2014, 08:50:33 am »
I don't have anything you need. I do want to see what your building though. What part of the CRD are you in?
1993 TD B3 Sedan
1992 G60 Syncro B3 Sedan
Reply #7January 13, 2014, 09:49:33 am
Spokerider
  • 195
« Reply #7 on: January 13, 2014, 09:49:33 am »
PM sent.
I'm interested......pm'd ya back
