Hydraulic hose will stand up to that oil temp?
Quote from: jlpst94 on December 30, 2013, 02:30:54 pmHydraulic hose will stand up to that oil temp? Braided line, must use braided. You'll be less likely to wear it out from the outside-in, and dump all your oil everywhere.Normal hydraulic hose will last past 200f degrees, but will harden after repeated heat cycles and over time. I'm talking normal 2wire/4wire stuff. I've replaced a bunch (and added heat exchangers in the process.) I liked using the push-lock stuff for lower pressures, but the line is much less robust.
I used one of these for mine:http://www.darksidedevelopments.co.uk/products/custom-turbo-oil-return-line-1-9-2-0-tdi.html
The turbo drain line is made for itThe right sizeNot expensiveIn the USWhat's the problem with that?
Quote from: jb86 on January 03, 2014, 05:32:06 pmThe turbo drain line is made for itThe right sizeNot expensiveIn the USWhat's the problem with that?nothing, just looks suspiciously like silicone heater hose that i can get for $6/ft elsewhere. http://www.ebay.com/itm/180218835033
