Author Topic: Cylinder head for 1.5  (Read 3329 times)
November 23, 2013, 08:34:34 am
aki91
« on: November 23, 2013, 08:34:34 am »
Hi guys, i am new here.
i have golf mk1 from '78 1.5 diesel, an i want to know if i had a crack cylinder head can i replace it with 1.6 engine head.
I want to know are those two head have some differences. Thanks
Reply #1November 23, 2013, 10:30:18 am
Re:
« Reply #1 on: November 23, 2013, 10:30:18 am »
First off where is the crack? If it is between the valves that is fairly normal.
The early 11mm mechanical 1.6 heads will bolt up to the 1.5 fine. I think the prechamber is slightly larger though so your compression will drop a bit.
Reply #2November 23, 2013, 04:23:41 pm
aki91
Re: Cylinder head for 1.5
« Reply #2 on: November 23, 2013, 04:23:41 pm »
Thank you, that is very useful information.
World best  ;D
Reply #3November 24, 2013, 10:27:40 am
Re:
« Reply #3 on: November 24, 2013, 10:27:40 am »
early 11mm 1.6 had a bigger oil drain tho.. the front oil drain will leak.
Reply #4November 24, 2013, 12:08:00 pm
Re:
« Reply #4 on: November 24, 2013, 12:08:00 pm »
Learn something new every day!
Reply #5November 24, 2013, 09:21:28 pm
81 vw pu
Reply #6November 28, 2013, 10:58:12 am
« Reply #6 on: November 28, 2013, 10:58:12 am »
if that thing presses in the front oil drain, and gets indexed properly, then i don't see why it wouldn't work..
either that, or install it, and put a set-screw or 2 in the head casting to hold it in place..
