Author Topic: intermittent steering wheel vibration  (Read 8132 times)
Reply #15November 24, 2013, 06:31:48 pm
bbob203
  • 1789
Re: intermittent steering wheel vibration
« Reply #15 on: November 24, 2013, 06:31:48 pm »
inner cv axle rebuild kit 98.00 new axle 98.00  ??? ::)
92 Passat wagon M-TDi
03 Jetta wagon TDi
VE Timing tools for rent
Reply #16November 24, 2013, 06:47:05 pm
dieseljunkie69
  • 47
    81 Jetta
« Reply #16 on: November 24, 2013, 06:47:05 pm »
Stupid right?
I'm That Guy.
Reply #17November 25, 2013, 08:29:54 pm
Dakotakid
  • 1240
« Reply #17 on: November 25, 2013, 08:29:54 pm »
Well, there is one other consideration:
On these Mk. II's, the long driveshaft (passenger) came with the large rubberized (red in color as I remember) vibration dampeners. Over time, they become damaged and the bonding on them (from time) goes kaput. Then they fall off or are removed due to rotational force or mechanics. A few of my cars still wear these.
I'm willing to bet yours does not.
Reply #18November 25, 2013, 08:37:59 pm
bbob203
  • 1789
« Reply #18 on: November 25, 2013, 08:37:59 pm »
The car in question is my b3 and it actually still does have it on there last i was under the car. I will recheck though when I get home tomorrow. I hear replacement axles don't have them either...
03 Jetta wagon TDi
Reply #19December 01, 2013, 08:19:57 pm
2strokesmoke
« Reply #19 on: December 01, 2013, 08:19:57 pm »
I had a slight vibration on my 81 Caddy,which drove me crazy.
I had just replaced EVERYTHING in the front suspension & steering,4 new tires,balanced(they had to rebalance to get it right)
Rims & hubs where straight,CV joints were nice-no play
Drove me crazy !
At first it seemed random,would come & go while cruising on the highway
After carefully monitoring,I noticed it would only happen going UP hill - Not on level ground,not down hill.
Straight road or curved road didn't effect it- Only Up hill
I finally got fed up and threw a pair of New drive axels in ( everything else was new,so why not ? )
Solved the problem - No more vibration
Sometimes narrowing down the source of vibration-is a time consuming pain in the A___ !
Best of luck - Hope yours is something simple
Mike
