Author Topic: Wanted for experimentation  (Read 4331 times)
November 16, 2013, 07:16:28 am
« on: November 16, 2013, 07:16:28 am »
If someone has an AAZ 2 piece pulley they don't need, I would like to have it for an experiment. Let me know please.
Reply #1November 16, 2013, 05:52:48 pm
410
  • 581
Re: Wanted for experimentation
« Reply #1 on: November 16, 2013, 05:52:48 pm »
What kind of experiment? 8)
Reply #2November 16, 2013, 06:25:14 pm
« Reply #2 on: November 16, 2013, 06:25:14 pm »
rover pump, belt alignment...
Reply #3February 11, 2014, 07:02:33 am
« Reply #3 on: February 11, 2014, 07:02:33 am »
Bump for science if anyone has a pump pulley for me let me know.
Reply #4February 11, 2014, 08:11:46 am
« Reply #4 on: February 11, 2014, 08:11:46 am »
The AAZ two part sprocket still uses the 17mm shaft.  The rover shaft is 20mm and because of that, the AAZ hub/sprocket will not fit.
Reply #5February 18, 2014, 10:48:50 pm
« Reply #5 on: February 18, 2014, 10:48:50 pm »
I've got a spare Rover hub if that's of any use for your experiment.  I can tell you it definitely does not have the right offset for the ALH pulley.
Reply #6February 19, 2014, 05:01:15 am
« Reply #6 on: February 19, 2014, 05:01:15 am »
I would be interested. PM me a pic if you have one and I will see what we have.
