Author Topic: power steering pumps in MK2 and MKIV  (Read 3711 times)
October 28, 2013, 07:11:30 am
« on: October 28, 2013, 07:11:30 am »
From what I can see both have an m16-1.5 threaded port...in theory I am wanting to see if the lines could be bolted onto either pump. The Jeep Wrangler I am working on the pump lines for its power steering will bolt onto the MKIV as I have seen it on another guys build. I have a PS pump from a MK2 and don't want to buy anymore if I don't have to. Also I don't want to make a bracket for the Jeep pump to fit on the VW engine.
Reply #1October 28, 2013, 11:17:51 am
Re: power steering pumps in MK2 and MKIV
« Reply #1 on: October 28, 2013, 11:17:51 am »
mk4 pump and bracket in different place then mk3 and mk2...
for bbob's we used mk3 set up on his mk2/b3... feed line was direct swap even though one was banjo vs threaded line..
Reply #2October 28, 2013, 01:49:50 pm
bbob203
  • 1789
« Reply #2 on: October 28, 2013, 01:49:50 pm »
the fitting for the banjo vs pressure fitting is just and adpater. banjo uses no adapter.
92 Passat wagon M-TDi
03 Jetta wagon TDi
VE Timing tools for rent
Reply #3October 28, 2013, 01:55:15 pm
« Reply #3 on: October 28, 2013, 01:55:15 pm »
direct swap on yours.. did not have to change anything bbob...
Reply #4October 28, 2013, 05:11:42 pm
« Reply #4 on: October 28, 2013, 05:11:42 pm »
The position of the bracket I don't care, I just need to know if it was possible to attach the lines from a MKIV to a MK2 pump.
