Author Topic: WTB: Mk1 TD oil pan, Mk1 alt/AC bracket  (Read 8619 times)
October 22, 2013, 07:42:30 pm
« on: October 22, 2013, 07:42:30 pm »
As stated.
Need a Mk1 TD pan with the drain line connection.
Also need a Mk1 alternator bracket from a car with AC. Alternator bolt bushing must be in good shape - aka not ovaled out and not stuck.
Reply #1October 22, 2013, 11:28:52 pm
Re: WTB: Mk1 TD oil pan, Mk1 alt/AC bracket
« Reply #1 on: October 22, 2013, 11:28:52 pm »
you do know mk1 and mk2 oil return lines into the pan are different correct??
i highly suggest mocking it up and determine in the line fits in angled to a 11 o clock or 1 o clock direction..
mk1 should be 11o clock position...
Reply #2October 23, 2013, 04:36:42 am
Re:
« Reply #2 on: October 23, 2013, 04:36:42 am »
Yes...
This is to replace the oil pan on my 84 1.6TD, like for like.
Reply #3October 29, 2013, 12:26:10 pm
  • 2932
« Reply #3 on: October 29, 2013, 12:26:10 pm »
I'll check my AC brackets.
Reply #4October 29, 2013, 05:41:42 pm
« Reply #4 on: October 29, 2013, 05:41:42 pm »
Probably why the original post and thread title say mk1 td oil pan haha
Reply #5October 29, 2013, 06:25:12 pm
« Reply #5 on: October 29, 2013, 06:25:12 pm »
hey as long as he is 10000000% positive no one ever did a engine swap.. or ruined the mk1 pan and retrofitted a mk2 line and pan.. ok... i can care less.......... i told him what makes one mk1 vs mk2... so if all else fails someone does not sell him wrong one...
but f you 8v... i knew why i said something... the op may not get it.. but at least a seller would...
you just need the main cast ac bracket or all the parts?? make sure where the ac comp mounts to the bracket are nice and perfect.. if someone left the ac comp loose after belt adj they wear in odd ways.. and unless perfectly flat will ruin good ac compresors as they do not fit properly.. a file/grinder can fix some...
Reply #6October 29, 2013, 06:30:54 pm
« Reply #6 on: October 29, 2013, 06:30:54 pm »
So say that then ;) Don't riddle it up.
"Are you absolutely sure you do not have an mk2 engine? They have a different pan and drain line, just so you are aware"
Reply #7October 29, 2013, 06:39:36 pm
« Reply #7 on: October 29, 2013, 06:39:36 pm »
no i consider the op as a flake as there is no riddle.. i asked him to make sure how the line goes in.. and how a mk1 is vs a mk2...
anyone looking to reply after my post could see my queston to go opps i got the wrong one... having pissing match w/you... again stupid... do not even get why you replied to it.. i know why i did.. so there is not a member trying to install mismatched parts like a year ago...
Reply #8October 29, 2013, 06:42:33 pm
« Reply #8 on: October 29, 2013, 06:42:33 pm »
Yeah. Ok. You've never made a pointless reply? My apologies, I have wronged.
And we knew this as the general public how?? I'm just saying, be more concise is all. Hard to fully understand something without the whole picture.
Reply #9October 30, 2013, 06:56:32 am
JessaBug
  • 112
« Reply #9 on: October 30, 2013, 06:56:32 am »
We did a full rebuild on this motor. Its a factory mk1 TD.
And pretty sure we just need the bracket.
Mine - BMP 20thAE GTI
His - '01 Jetta TDI
Our project: '84 Jetta TD
Reply #10October 30, 2013, 07:00:43 am
« Reply #10 on: October 30, 2013, 07:00:43 am »
I just sold the one I had, sorry. If you cannot find anything and it is needed right away, you could use some adapters on a bulkhead fitting. If not an emergency and you have time, then no big deal we will keep searching for you.
no idea on the alt bracket, but I am sure someone will have one.
Reply #11October 30, 2013, 07:38:10 am
« Reply #11 on: October 30, 2013, 07:38:10 am »
or you get a mk2 line and pan.. or mod a mk2 one (cut/weld)
unlike on a mk2... it has no rear mount in the way...
Reply #12October 30, 2013, 07:43:19 am
JessaBug
  • 112
« Reply #12 on: October 30, 2013, 07:43:19 am »
We had a leak at the drain bolt area that we noticed when we did the rebuild. We tried fixing it, but its still leaking. And we just switched to synthetic oil and now we have a much bigger oil puddle on our garage floor. We'd like to stay with the mk1 pan if possible. We'd really like to not have to mod stuff to fit. We have one more possible solution we're going to try. Fingers crossed it will work. Getting tired of having to clean up oil every time we move the car.
His - '01 Jetta TDI
Reply #13October 30, 2013, 07:48:25 am
« Reply #13 on: October 30, 2013, 07:48:25 am »
thats all....
pull the pan...
inside it is 2 spot welds holding the threaded area of the nut.. remove it and weld in a new nut inside the pan with drain plug... (i use the drain plug to hold the nut in place while welding)
ive done that lots of times on td pans...
just rebuild it. costs less and better when done..
« Last Edit: October 30, 2013, 07:50:48 am by CRSMP5 »
Reply #14October 30, 2013, 08:23:49 am
92EcoDiesel Jetta
« Reply #14 on: October 30, 2013, 08:23:49 am »
what's the difference between a MK1 and MK2 AC alternator bracket? Don't hey both mount on top of the water pump?
