Author Topic: my 1.6 n/a sucks... 70mph top speed and 30mpg  (Read 6651 times)
Reply #15March 19, 2006, 05:54:57 pm
gunny
  • 7
bad fuel economy
« Reply #15 on: March 19, 2006, 05:54:57 pm »
the first thing I would have changed were the fuel injectors, you can fiddle with injection timing all you want, but if your injectors are junk, it will not help. I would also to a compression check first, if thats cool, then get new MATCHED injectors, I bet you see a jump to at least 40 mpg then.
Diesels, reliants, and my dual sport bike
Reply #16March 19, 2006, 06:30:46 pm
shaskill
  • 10
« Reply #16 on: March 19, 2006, 06:30:46 pm »
Sounds like my posts from 6 months ago. When I eventiually had to repair an injector pump leak by doing a rebuild, I had a new car. Does 80, great mileage and no smoke. I tried all the things you did. Now I run on 100% SVO
Reply #17March 19, 2006, 11:34:32 pm
the4ork
  • 331
« Reply #17 on: March 19, 2006, 11:34:32 pm »
yeah i dont think my pump needs to be rebuilt... its the newest looking part under the hood... and its still all shiny looking sorta...
but i did discover i had a bad rear wheel bearing... i replaced it tonight and it was tore up... bad...
wonder if that could have played a heavy role in my declining fuel economy? and as far as injectors go... should i replace them with stock ones? do an upgrade? how much do they run?
Reply #18March 20, 2006, 06:36:39 am
wyldman
  • 403
« Reply #18 on: March 20, 2006, 06:36:39 am »
Take the injectors to an injection shop,and have them tested.They will tell you if they are good or not,and should also be able to rebuild them for you.
(416)565-7282
Reply #19March 21, 2006, 12:09:35 am
2mAn
« Reply #19 on: March 21, 2006, 12:09:35 am »
ricky, just pay charlie to fix it!!!
 i havent had any problems with my jetta since ive had him do the hard work for me. i still do the easy stuff, but damn man u dont know nada about diesels and you wanna time it yourself!!! i have a bentley too, if u wanna use it.
