Author Topic: Aaz power steering on a 1.6?  (Read 3466 times)
October 20, 2013, 07:54:31 am
shwak23
  • 417
    1990 VW Golf TD. Engine Code CY
    • Blackdog Junkyard
« on: October 20, 2013, 07:54:31 am »
The pump and bracketry should bolt up, correct? I currently have a MK1 non ac alternator mount installed. The aaz power steering brackets seem 1000x times better designed than the MK2 design. Plus as far as I can tell they are completely independent of the AC/Alternator brackets. Which is obviously beneficial when one is not running the original MK2 ac bracket.
Just wanted to be 100% sure they would bolt up perfectly. I would hate to get there and find one flaw that would ruin my day.
Sent from Outer Space!
Reply #1October 20, 2013, 11:38:42 am
Re:
« Reply #1 on: October 20, 2013, 11:38:42 am »
I know the pumps are different - the AAZ pump won't mount in the 1.6 bracket or vice versa. So you will have to use the pump that goes with the bracket.
Past that I can't say for sure. I thought the AAZ PS pump bracket attached to the alt bracket but I could be wrong.
Reply #2October 20, 2013, 10:55:08 pm
shwak23
  • 417
    • Blackdog Junkyard
Re: Re: Aaz power steering on a 1.6?
« Reply #2 on: October 20, 2013, 10:55:08 pm »
It may slightly but not as awkwardly as it does to the 1.6.
Or should I say not in a way that would overly concern me if that one bolt was left out.
Reply #3October 28, 2013, 07:04:16 am
1outof5
« Reply #3 on: October 28, 2013, 07:04:16 am »
Didn't quite understand if you have a mk1 golf or mk2. But if you are trying to put an AAZ pump on a mk1 PAS beware that the pipe fittings are different on the pump.
Reply #4October 31, 2013, 09:51:12 am
shwak23
  • 417
    • Blackdog Junkyard
« Reply #4 on: October 31, 2013, 09:51:12 am »
Putting it on a MK2.
Sent from my SCH-I605 using Tapatalk
Reply #5November 01, 2013, 03:39:50 pm
« Reply #5 on: November 01, 2013, 03:39:50 pm »
I have a Mk2 pump on my Mk3 so the fittings between Mk2 and Mk3 are the same... :)
