Author Topic: alternator went and now no tach after replacement  (Read 5641 times)
March 14, 2006, 01:26:29 pm
sethyboy85
  • 284
« on: March 14, 2006, 01:26:29 pm »
I was cleaning some carbon out of my car getting onto the highway yesterday when at 4800rpm my tach and battery light died/lit up... I thought I popped a belt, nooo so I drove home as quick and safely as possible since I was running out of day light.
get reamed buying an alternator
install it today and now the battery light is gone when I start the car up (self excites at 1100rpm) but no tach it doesn't work... I can't find my multimeter for the life of me to check if any voltage is coming out of the W terminal. checked all fuses traced W and W+ line from alternator to firewall where they disapear (appear to be fine) cleaned the connectors, still nothing.
I am done freezing my ass off but if my battery light isn't on I should be charging right? I drove around for 15min with fan on high, lights on, stereo on all the way and dome light on. never lit up the battery light
when sombody gets home I am going to have them find my multimeter they used last so I can check to make sure I am charging.
why does my tach not work? did it send a surge and blow out the tach, I have an extra one on my desk here but im not pulling that dash apart to get the tach out tonight.
91 Dodge Spirit R/T 2.2l T3/T4, Big valve head, 3" exh, NPR IC, goal. FS $4000
85 1.6lTD Garrett, NA34X mercedes INJ,2.5" turbo back- Sold
85 TD/91 Eco need to put together to make 1 good car
86 190D Merc with only 392k
96 Volvo 850 Turbo wagon, 1 grainger valve and 250hp/280tq
Reply #1March 14, 2006, 02:07:58 pm
wyldman
  • 403
« Reply #1 on: March 14, 2006, 02:07:58 pm »
Maybe the W terminal isn't connected inside the alternator ?
(416)565-7282
Reply #2March 14, 2006, 02:43:43 pm
sethyboy85
  • 284
« Reply #2 on: March 14, 2006, 02:43:43 pm »
I got the multimeter... have 12.3v from alt to battery neg or alt to block, have 12.3v from W+ to block or neg battery and 0v from W to anything....
so did the punks forget to hook up the W terminal considering it's a $190 alt I am going to raise hell
Reply #3March 15, 2006, 05:18:42 am
regcheeseman
  • 714
« Reply #3 on: March 15, 2006, 05:18:42 am »
First off, you mean D+ not W+ right???
You won't measure much from W term (and ground/block/earth/neg) with a multimeter - you may get something if you switch to AC voltage measurement but it won't be much.
It is incredibly unlikely that the terminal is not connected.
If you've got a spare tach, bodge some wires on and connect it up to your alt.
Reply #4March 15, 2006, 07:35:47 pm
sethyboy85
  • 284
« Reply #4 on: March 15, 2006, 07:35:47 pm »
no the directions I got with the alternator were very confusing, as in their lableing method... so I had to clean up my old Alt today to read what I had it plugged into before and moved one wire from the W+ to the D+ pin and all is better now... the directions were gay
Reply #5March 18, 2006, 04:42:38 pm
hillfolk'r
  • 1532
« Reply #5 on: March 18, 2006, 04:42:38 pm »
w lead is ac power,,,,read ac on that,,its from the stator output  before the diodes,,,i mod old alternators,so i canhook my vdo dieseltach up in my rabbit,,just soldering a wire in there no problem,,,either it isnt the w lead,,or your tach is fried,maybe like if the stator shorted or something,,but idoubt that, i remember reading the ac  voltage on the w lead rises with rpms,,,,lamp is out you should be charging,,i bet that w lead isnt correct or somethin like that,,,i coulda swornit read like 7 volts at idle and the most i saw was like 12 but i didnt rev it much,thats on the w lead,reading ac on your  multimeter,,cool you got it working,,,i called a few alt shops at first when i got my tach,,because ididnt know what a w llead was,,niether did they,,,,after calling vdo, they faxed me how to get a w lead out of any alternator, they were great,,that was funny,they didnt know either,these auto electric rebuild shops,,this was before iwent to school,and was trying to learn about cars,and after that i knew that if you didnt doit yourself,it wasnt gonna be right!!! if ya get a chance sethy,,check it again,,i cant remember the voltage,,but basically the tachis reading the frequency change,,the ac for the w lead is just a signalwire basically
Throttle cables ftw
