Author Topic: Best way to get parts for my US based AAZ?  (Read 5002 times)
October 12, 2013, 07:38:32 pm
JimEG
  • 32
« on: October 12, 2013, 07:38:32 pm »
What is the best way way for me to get parts for my AAZ, here in the US?
Online vendor? I'm doing a conversion to a Vanagon, so what vehicle do I use for reference?
Things I can think of that I'll need soon -
Gaskets
Seals
Timing belt/kit
Power steering pump belt(no ac)
Upper timing cover(if I can't find a used one here)
Reply #1October 12, 2013, 07:43:07 pm
bbob203
  • 1789
Re: Best way to get parts for my US based AAZ?
« Reply #1 on: October 12, 2013, 07:43:07 pm »
where are you located?
92 Passat wagon M-TDi
03 Jetta wagon TDi
VE Timing tools for rent
Reply #2October 12, 2013, 07:57:55 pm
JimEG
  • 32
« Reply #2 on: October 12, 2013, 07:57:55 pm »
Near Seattle WA
Reply #3October 12, 2013, 08:02:53 pm
bbob203
  • 1789
« Reply #3 on: October 12, 2013, 08:02:53 pm »
Near Seattle WA
Maybe order all the stuff through an auto parts store/dealer across the border and pick it up there? I think oreilly can order the stuff for an aaz like tbelts. They sell good timing belt stuff if you pick gates.
03 Jetta wagon TDi
Reply #4November 06, 2013, 08:13:42 am
« Reply #4 on: November 06, 2013, 08:13:42 am »
Gaskets - with the exception of the headgasket use a 1998 Jetta TDI
Seals - Same as above
Timing belt/kit - If you have an early head with the larger stud use 1.6 parts. If it's the later head with the smaller stud, use a 1.6 belt and the 1998 TDI tensioner. You can probably use the TDI belt as well but I'm not positive about tthat.
Power steering pump belt(no ac)- Just find the belt length and order that one from anywhere.
Upper timing cover(if I can't find a used one here)  I think you can make a TDI one work. Again, 98 Jetta.
Reply #5November 06, 2013, 08:48:29 am
« Reply #5 on: November 06, 2013, 08:48:29 am »
i think tbelts are all basically the same
alot of parts stores can order in canadian parts, almost 100% certain napa can.
Reply #6November 06, 2013, 05:20:51 pm
Syncroincity
  • 727
« Reply #6 on: November 06, 2013, 05:20:51 pm »
Couple of gotchas on the AAZ;
If replacing the valve stem seals, measure the old ones, there's 7mm and 8mm valves in the AAZ, depending on year.
Head gasket aftermarket brands only come in 2 or 3 notch, if you need the thinnest 1 notch you need to go through a VW dealer. Make sure you don't order or get sent a TDI head gasket, not the same.
www.autohausaz.com
JC McCavitt
'86 Syncro GL Camper AAZ
'98 Jetta Wolfie
Reply #7November 06, 2013, 05:33:59 pm
Gizmoman
  • 1301
« Reply #7 on: November 06, 2013, 05:33:59 pm »
Another AAZ gotcha would be a 1 notch HG. They can be found, but you'll need patience on shipping no one stock them locally.
Possibly crossing the Border if needed.
Reply #8November 06, 2013, 10:34:01 pm
« Reply #8 on: November 06, 2013, 10:34:01 pm »
If for some reason you need a 1 notch headgasket I can order that for at better prices than the dealer.
I can actually order any of the parts you need.
Reply #9November 07, 2013, 02:27:47 am
homerj1
  • 433
« Reply #9 on: November 07, 2013, 02:27:47 am »
Being in Canada, I  usually order thru  http://www.autopartsway.ca/
Not sure if they deliver to the US
But these guys do - http://www.canadapartsonline.com
Although I haven't used them for a while.
Reply #10November 12, 2013, 07:07:31 pm
« Reply #10 on: November 12, 2013, 07:07:31 pm »
www.RockAuto.com
If I lived in the states.. I'd have an order from them to my door every 2 weeks. SO MUCH STUFF!
Reply #11November 13, 2013, 06:19:17 am
« Reply #11 on: November 13, 2013, 06:19:17 am »
not that anyone is thinking of trying it, but i would almost guarantee that a tdi gasket will leak compression into the coolant on an aaz.
Reply #12November 14, 2013, 03:51:03 pm
CrazyAndy
  • 739
« Reply #12 on: November 14, 2013, 03:51:03 pm »
Confirmed;  I have parsonally purchased a lot of parts for the AAZ through NAPA.  Granted, many have to be special ordered, but they can get them.  Just provide part number, and they will get you OEM brands under their umbrella european importing brand Altrom Imports.
www.RockAuto.com
This also, as they have good closeout deals.  Just make sure to be careful the part you're buying has the correct part humber and looks like what you are replacing.
Also try AutohausAZ.com for some smaller parts; use a 1996 Jetta TDI under vehicle selection, the engine code will still say AAZ.
Why?
Reply #13November 15, 2013, 04:25:15 am
« Reply #13 on: November 15, 2013, 04:25:15 am »
www.RockAuto.com
Why?
yes i love altrom, i never get napas parts if they can order the altrom stuff instead.
tdi gasket doesn't have that extra foil part that goes under the pre cup, so compression could leak around that way.  not sure if the aaz gasket uses foil like 1.6td, but u get the idea.
Reply #14November 21, 2013, 05:40:52 pm
Luckypabst
  • 502
« Reply #14 on: November 21, 2013, 05:40:52 pm »
Partsgeek.com lists AAZ specific parts... delivered from US based distributors at (usually) better prices, accessed from the convenience of your computer.
Chris
'82 TD Westy
'81 NA Caddy
