Author Topic: Volvo D24 Glowplug choice  (Read 3738 times)
October 09, 2013, 05:33:57 am
ian2000t
  • 10
« on: October 09, 2013, 05:33:57 am »
Hi all, I've got a D24TIC Volvo which needs new glowplugs.
I run it on Veg oil (single tank) so need some good glowplugs. On the "Veggie forum" most use Bosch Duraterm's which seem to be most reliable. But, it looks like there are 2 different types:
GLP002 - 0250201032 - £6.82 - http://www.gsparkplug.com/shop/glow-plugs/bosch-0-250-201-03...
GLP085 - 0250201046 - £8.42 - http://www.gsparkplug.com/shop/glow-plugs/glow-plugs-bosch-0...
Supposedly the GLP085's are "Duraterm Chromium" plugs. Has anyone ever used these? Are they worth the extra £12 for a set?
Also, I'm sure I read a while back about fitting longer plugs in the 1.6TD's when running Veg oil - is that true? Would that apply to my Volvo?
Volvo 760 TD (D24TIC), 16psi boost, reground LDA pin, Monark 273 (GTD) nozzles @ 163 bar. Running 85/15% Veg/RUG.
Reply #1October 09, 2013, 05:52:08 am
  • 1739
Re: Volvo D24 Glowplug choice
« Reply #1 on: October 09, 2013, 05:52:08 am »
The links for those glow plugs don't work for me. Either way, you may want to check out "pimping the glow plugs" with a search on this site. Because you are in the UK, are you using a single tank or double tank
set up ? If you are using 2 tank,it shouldn't matter about the glow plugs-as long as they are working properly. If using a one tank, you may want to do a bit more research about having a longer,hotter duration plug and relay.Maybe Elsbett have something for a retrofit? Either way, good luck changing #6 plug that's behind the pump
Reply #2October 09, 2013, 06:02:50 am
ian2000t
  • 10
« Reply #2 on: October 09, 2013, 06:02:50 am »
Will look into the Pimping, thanks!
I run a single tank - normally with 10% unleaded mixed in, or 20% diesel. It's a bit of a cranky start but never lets me down (touch wood).
Glowplugs now are on a manual switch. I turn the switch on for 15-20 seconds then start the car with them on, and turn them off after about 15-20 seconds of idling.
Couple of mine died though after I left the manual switch on for an hour on my driveway...  :-[
Couldn't find any info about longer plugs, just think I remember reading something a while back.
I did change them a couple of years ago and used BERU plugs, so I know the pain no.5&6 cause!!
Reply #3April 06, 2015, 02:12:00 am
Petmill
  • 2
« Reply #3 on: April 06, 2015, 02:12:00 am »
Caveman is right, ELSBETT or better ANC does offer glow plugs and nozzles for this model. I think they have different dimensions and more power.
