General Information
Troubleshooting
Engine compatability
Topic: Engine compatability (Read 4973 times)
September 28, 2013, 04:24:30 pm
Turftech
September 28, 2013, 04:24:30 pm »
I have an opportunity to scoop a very clean '95 diesel Golf with no engine/transaxle for free. I already have a 1.6 TD (MF) engine from a type 2 Jetta ('90) and wonder what sort of mods I will have to do? Is it just a matter of finding the right transaxle?
Cheers!
'90 Jetta GL TD 570'000 Kms and counting (Gave her to a friend)
'92 Passat G60 Syncro Wagon 180'000kms. TDI conversion project
'87 Jetta Coupe 325'000kms. MF IDI conversion project
September 28, 2013, 08:21:03 pm
Re: Engine compatability
September 28, 2013, 08:21:03 pm »
It is a matter of engine mounts.
October 01, 2013, 02:00:48 pm
Turftech
October 01, 2013, 02:00:48 pm »
Yes, I figured that much. But in what way? From what I have found so far it looks as though it is only the rear transaxle mount that is different(?) Will a type 2 transaxle already have the needed mount points on it for the type 3 mount, or do I have to use a transaxle from a type 3? The mounts, engine and transaxle are all missing on this car so I will have to scoop those from the wrecker and a local parts supplier out here. (AVR Imports in Abbotsford)
Thanks.
October 01, 2013, 05:15:54 pm
October 01, 2013, 05:15:54 pm »
You need to get away from calling them Type 2 and Type 3
Type 2
Type 3
Mk1, Mk2.. Or A1 and A2.. Lol not a big deal, just so that people will know definitively what you are talking about.
I am thinking the mk2 and mk3 transmissions use a similar mount on the transmission side, it is only the body side that may be different. You need the mount for the specific body, most transmissions accept all of them with the exception of some. You'd need to check that first.
October 02, 2013, 07:42:39 am
Turftech
October 02, 2013, 07:42:39 am »
Thanks. That is exactly what I needed to know. And I will in future use the correct nomenclature when referencing models. I should know better as I used to own a type 2 myself! ('78)
Man, I would give my left nut for that type 3... Quite possibly my all time favourite car.
October 02, 2013, 10:16:07 am
Re: Re: Engine compatability
October 02, 2013, 10:16:07 am »
I've got an MF in a '94 so any questions you might have I should be able to help with. The mounting brackets need to be the Mk3 versions but the 1990 engine and transaxle will have the correct bolt holes.
Sent from my HTC One X using Tapatalk 2
October 02, 2013, 10:58:17 am
October 02, 2013, 10:58:17 am »
The rear engine mount is definitely different on the mk2 vs mk3. The power steering pump will give you some troubles but nothing serious.
October 02, 2013, 02:23:20 pm
October 02, 2013, 02:23:20 pm »
Front and rear engine mount brackets are different, but both will bolt to either an AAZ or an MF. The power steering pump is different, but the MF power steering pump will run the Mk3 power steering rack fine. The Mk3 hoses will connect to the Mk2 pump.
General Information
Troubleshooting
