Author Topic: WTB: AAZ performance clutch  (Read 5316 times)
September 16, 2013, 03:45:03 pm
tdotdub
  • 52
« on: September 16, 2013, 03:45:03 pm »
sick of having sliping clutches! looking for a kit that will hold 120-140hp. message me what you have, links for new ones will help as well as I haven't been able to find any for sale for AAZ. I don't care for what flywheel it is 1 or 2 pin.
are 8v performance clutches the same as diesel ones? would those work? looking for suggestions.
87 Audi 5000S Quattro Turbo Diesel (the car I want to light on fire everyday)
99 Beetle TDI (the beater)
99.5 Cabrio  (the innocent one)
Reply #1September 16, 2013, 03:53:55 pm
Re: WTB: AAZ performance clutch
« Reply #1 on: September 16, 2013, 03:53:55 pm »
So long as it is the right size disk, and as well as the right spline for your transmission. Yes, any mk1-2-3 8v clutch setup will work so long as they are also for the 020 transmission.
Reply #2September 16, 2013, 05:00:49 pm
bbob203
  • 1789
« Reply #2 on: September 16, 2013, 05:00:49 pm »
upgrade to an 02a and run a vr6 pp and tdi disc.
92 Passat wagon M-TDi
03 Jetta wagon TDi
VE Timing tools for rent
Reply #3September 16, 2013, 06:12:46 pm
« Reply #3 on: September 16, 2013, 06:12:46 pm »
HP doesn't slip the clutch, torque does.
Reply #4September 16, 2013, 07:37:11 pm
« Reply #4 on: September 16, 2013, 07:37:11 pm »
There is a big spline 020 clutch. I don't know but was thinking it came in the MK3.
I never had issue with my 210mm luk clutch for the aaz. I bought it for around 160.00 came with the throw out bearing, alignment tool, pp, and clutch. I didn't slip it in 10,000 miles probably had around 150hp in the old engine. Don't know how much torque.
Similar to this one...
http://www.ebay.com/itm/LuK-17-012-New-Clutch-Set-/400548294014?pt=Motors_Car_Truck_Parts_Accessories&fits=Make%3AVolkswagen&hash=item5d4289ed7e&vxp=mtr
Reply #5September 16, 2013, 08:57:11 pm
spencebm
  • 686
« Reply #5 on: September 16, 2013, 08:57:11 pm »
I run an AAZ with a 16v 020 pressure plate/8v disc (210mm)/ 210mm gas flywheel and have had no problems.
Ben Spencer
Reply #6September 17, 2013, 08:01:21 pm
« Reply #6 on: September 17, 2013, 08:01:21 pm »
I have an AHU in my mk1 with the 210 8v gas sachs setup. Flywheel, Pressure Plate and Clutch Disk.
I can slip it in 5th gear if I get on the power too aggressively.
Reply #7September 18, 2013, 12:10:47 pm
tdotdub
  • 52
« Reply #7 on: September 18, 2013, 12:10:47 pm »
so an AHU tranny? and has anyone else done that no issues?
I run a t3 turbo so boost comes on like a snail it slips only 3 gear and up and only sometimes...
« Last Edit: September 18, 2013, 12:24:50 pm by tdotdub »
Reply #8September 18, 2013, 12:16:19 pm
tdotdub
  • 52
« Reply #8 on: September 18, 2013, 12:16:19 pm »
where can I get this combo?
that's what I originally wanted but couldn't find it and ended up going with a local company that someone suggested and its complete crap what they made....
this one here>> id stay away, first time the fly wheel they gave was not machine properly, second time after well its still sliping...http://www.euro-drive.com/contact/default.asp
the spline on mine is a 24 tooth correct? how can I find out?
« Last Edit: September 18, 2013, 12:22:27 pm by tdotdub »
Reply #9September 18, 2013, 10:11:26 pm
spencebm
  • 686
« Reply #9 on: September 18, 2013, 10:11:26 pm »
autohausaz.com
order everything separately and you are golden.
Ben Spencer
Reply #10September 19, 2013, 03:04:08 pm
CrazyAndy
  • 739
« Reply #10 on: September 19, 2013, 03:04:08 pm »
Quoted for truth.  And make sure it's a Sachs clutch, as the Luk kits hold a little less than the Sachs kits, which can hold as much as 290-300 ft-lbs of toruqe.
Also, what car is this for?  The 5K?  The beetle already has a 228mm clutch stock, and runs an 02J trans.  The 5K is longitudinal, and I don't know what clutch diameter they use.  Come to think of it, I don't know anything about 5ks or quantums.
Reply #11September 19, 2013, 05:23:44 pm
« Reply #11 on: September 19, 2013, 05:23:44 pm »
I have read the luk kits are better by 10% and trust them fully. Sachs is what I replaced in my mkiv as it was slipping...
You could take my recommendation if you do not want to step up to the 02A. I have ran south bend, luk, clutchnet, and sachs. Sachs is the only brand I have slipped. For an OEM type clutch I fully recommend LUK. For a performance daily I recommend south bend, and for all out performance I recommend the clutchnet or a higher end southbend.
Reply #12September 26, 2013, 01:12:27 pm
moldovadizel
  • 5
« Reply #12 on: September 26, 2013, 01:12:27 pm »
just figured out how to register so I did....was using a friends account tdotdub for my cabrio questions
I have a south bend in my alh and its a monster clutch, I only wish they had one for an aaz.
doing the 16v pp and gas flywheel sounds like the most budget friendly way, so thanks for the website link!
once I do that gotta install that 6.5td gm lift pump I bought, intercool it and call it a day :) the aaz potential is awesome.
« Last Edit: September 26, 2013, 01:14:04 pm by moldovadizel »
