Author Topic: b3/b4 parts about to goto dump...  (Read 3878 times)
September 01, 2013, 09:51:05 am
« on: September 01, 2013, 09:51:05 am »
from 97 tdi sedzn... if you do not see it listed ask... but swap is a complete swap..
tdi running swap.. i am actually cutting the front clip off to keep it a running swap.. 1500 as fuel pump sprung a leak at the electrical connector.. gotta buy top of pump to fix... = fail... libby pump = best solution.. damb near same price... ac still blows cold.. new rad/condensior... t-belt/maintence done with in last 30k.. including intake cleaning..
real black plastics (perfect for high cick the plastic areas when you want black.. .. all but seat belt stuff... from a b3... fits b4 nice... even have black carpet... i prefer to not ship.. too many things. talk to bbob as he travles the country alot and may be a cheap shipping method.. $100
front b4 seat belts/plastics.. was tan.. sprayed flat black.. find it adhears beter to plastic and to make shine use something that does.. :P these front seat belts do not fit a b3... rumor is mk2 2 door will work.. but you still need the rest of this crap.. :P $50 and ill include the parts that do not fit..
now.. fyi.. all the lower plastics, front seat belts so on fit wagon.. but the upper rear and upper around rear door are different.. but in a wagon.. paint work wells as its not something you kick with your feet...
--------------------------rear gas sachs shocks.. been installed for 15k.. ------------------------- 75+shipping  can fab receipt for life warnetee..
Reply #1September 02, 2013, 02:05:19 pm
Re: b3/b4 parts about to goto dump...
« Reply #1 on: September 02, 2013, 02:05:19 pm »
well 2/3 of it in 20 pieces on trailer....
front clip still runs, ac/heat works... not a single cut wire yet... not even touched the fusebox!! i rolled/zip tied all the rear harness to the front door hing.. :D all i need is a jerry can to feed it fuel... hell lines cut by tank and pulled to the front so alli have to do is set then in a can.... i need to bypass the clutch switch.. ill unplug/jumper... no brake fluid in it to operate clutch and i do not want to depress the pedal and wash them dry... the master/slave 13 or so mo old...
got all kinds of little b4 crap... if dumpster gets dumped... well when it gets dumped.. it goes away... ive filled it up with shop cleaning crap.. so in the am or 7 days it will be pitched... speak up...
lots of perty black inhterior stuff... hate to pitch.. but too much plastic for me to store into winter... end of oct it will be pitched... my car has black set...
no bottom half door stuff.. but idea of how 2 tone looks... hate leather.. in my wagon i have grey cloth vs the tan leather... and imo both looked better with 2 tone vs 1 solid...
Reply #2September 07, 2013, 09:29:24 pm
nwcali6
  • 69
« Reply #2 on: September 07, 2013, 09:29:24 pm »
I'm looking for a passenger side front turn signal, not sure what happened to mine.  Rh mirror would be nice as well (electric would be nice).
Reply #3September 08, 2013, 04:25:40 am
« Reply #3 on: September 08, 2013, 04:25:40 am »
got both.. mirror is silver... lense has few "sun" type of cracks from being old plastic.. i tossed the reflector section as they were real ugly..
sun----- goofy hairline cracks from heat/expansion/break down of old plastic..
we will say 60 shipped..
Reply #4September 14, 2013, 08:22:43 pm
wisconsinjohnson
  • 26
« Reply #4 on: September 14, 2013, 08:22:43 pm »
headlite buckets?
Reply #5September 15, 2013, 03:20:43 am
« Reply #5 on: September 15, 2013, 03:20:43 am »
the japan hella e-codes sold while ago... sold local as online folk  felt 300 was too much... those hard to find but worth every penny...
