Author Topic: idi turbo pump on a mk4 tdi  (Read 3996 times)
March 12, 2006, 08:54:10 pm
juggernaut350
  • 4
« on: March 12, 2006, 08:54:10 pm »
I have a question maybe someone can help me on? I have a mk4 tdi motor injectors and lines. Will a 1.6 idi turbo pump be sufficient fuel pressure for the tdi injectors?
Reply #1March 17, 2006, 12:58:22 pm
tomo
  • 2
« Reply #1 on: March 17, 2006, 12:58:22 pm »
Don't do that.IDI pump has 9mm plunger and low cams o n cam plate.
Reply #2March 18, 2006, 10:55:00 am
hillfolk'r
  • 1532
« Reply #2 on: March 18, 2006, 10:55:00 am »
ive got a 12mm head on an idi turbopump,,runs good,,im using kerma 520 race nozzles,but i have some (tuning) issues withmy pump,,,but it runs good other than a wierd qwurk that ive shimmed the intermediate spring on the gov,,but the revs wont drop when spun up past 3000,,,,,i  hate computers because iwork on them all day,so i went low tech mechanical on my ahu tdi in a 79 rabbit,,,kinda like a mechanic has a falling apart car,,,,all in all i believe you can get the same power regardless of electronic or mechanical,,,,get your pumpmodded with a bigger plunger+run it!!!!
Throttle cables ftw
Reply #3March 20, 2006, 04:37:20 pm
hillfolk'r
  • 1532
« Reply #3 on: March 20, 2006, 04:37:20 pm »
this pump had some issues,before all this,so dont let me throw ya off,,you may need a 10mm plunger,,i thought somewhere someone said that a stock idi pumpwill run and drive,,but if you want power,keep dreamin,it wouldnt even make stock tdi hp,,,,,,,but it would run,, :roll:
Throttle cables ftw
