Author Topic: FS CE1 cluster with tach  (Read 4485 times)
August 21, 2013, 07:01:28 pm
« on: August 21, 2013, 07:01:28 pm »
SOLD
I have for sale a CE1 cluster from a 89 Jetta TD. As long as your car is 85-89 (CE1) this is plug and play if your alternator has a working W terminal.
I'm asking $110 shipped to the USA, $100 in Canada.
I know for sure that the tach and temp gauge work. I believe all the LEDs work as well. I do not know if the speedometer and odometer work because the speedometer cable was not plugged in when I was testing it.
Click the pics for full size.
« Last Edit: September 05, 2013, 10:41:30 am by burn_your_money »
Reply #1September 03, 2013, 09:02:14 pm
Kazuki
  • 61
Re: FS CE1 cluster with tach
« Reply #1 on: September 03, 2013, 09:02:14 pm »
pm sent
Reply #2September 04, 2013, 03:58:35 am
« Reply #2 on: September 04, 2013, 03:58:35 am »
fyi... old speedo cable piece.. drill that is "reversed" you can test speedo... thru math and stop watch you can time the odo even... to see if it slips.. but gotta have a reverse drive drill...
Reply #3September 04, 2013, 06:31:30 am
« Reply #3 on: September 04, 2013, 06:31:30 am »
Don't all drills have reverse? I'm not overly worried about the speedo as I think most people will swap their own in anyways. If anyone interested wants me to hook it up to a drill though I can give it a shot.
Reply #4September 04, 2013, 08:28:54 am
« Reply #4 on: September 04, 2013, 08:28:54 am »
now when using a air drill... :D back in day.. :P you do not wanna know how many i used to do speedo gears on... final gear check was drill and run it 2 miles.. i cannot explain why air vs electric though... always kinda scratched my head on that...
Reply #5September 04, 2013, 08:58:26 am
« Reply #5 on: September 04, 2013, 08:58:26 am »
Right air drills, I forgot about those. Thanks for the tip
