Author Topic: Vacuum pump o-ring?  (Read 4449 times)
July 27, 2013, 07:02:02 pm
jaed_43725
Vacuum pump o-ring?
« on: July 27, 2013, 07:02:02 pm »
I need either the size or preferably P/N for the o-ring that is under the lid? Or possibly if there is another o-ring that is the same one? Any help is greatly appreciated.
Reply #1July 28, 2013, 05:42:47 am
Re: Vacuum pump o-ring?
« Reply #1 on: July 28, 2013, 05:42:47 am »
I know I have used the IM seal carrier oring and it worked fine. Dealer has the correct one as I have used it too, but I don't know the number sorry.
Reply #2July 28, 2013, 07:13:19 am
jaed_43725
« Reply #2 on: July 28, 2013, 07:13:19 am »
I found this: "coke
 Post subject: Re: Front Crank Seal ReplacementPostPosted: Sun Apr 10, 2011 12:06 pm
Camshaft, Crankshaft and IM shaft oil seal are all the same seal. The intermediate shaft seal carrier o-ring should be green and is usually very thin."
Is this correct?
Reply #3July 28, 2013, 09:48:25 am
jaed_43725
« Reply #3 on: July 28, 2013, 09:48:25 am »
 The intermediate shaft seal carrier o-ring may be the thing I am looking for. But those oil seals are not even close.
Reply #4July 28, 2013, 10:37:36 am
« Reply #4 on: July 28, 2013, 10:37:36 am »
Right the green o ring that is under the IM shaft seal carrier *seal carrier o ring as stated before* is what I used in one of my vane pumps. VW dealers have the real o ring and the IM shaft seal carrier. I used the IM one as I had 3 laying around for my build and when I took the one out and held it up to the new green IM one it looked the same. I don't know if it is or not but it worked for me. Your results may vary.
Reply #5July 28, 2013, 11:09:35 am
« Reply #5 on: July 28, 2013, 11:09:35 am »
IM shaft seal carrier o-ring is a bit large in diameter.  I've gotten viton ones from 'the o-ring store' online.  Part number v2.00x055 fit perfectly.
Reply #6July 28, 2013, 01:10:20 pm
jaed_43725
« Reply #6 on: July 28, 2013, 01:10:20 pm »
Reply #7July 28, 2013, 01:58:01 pm
« Reply #7 on: July 28, 2013, 01:58:01 pm »
Sure, if you want to get the o-ring that is too large instead of the one that is a perfect fit that I posted above...
Reply #8July 28, 2013, 02:35:29 pm
jaed_43725
« Reply #8 on: July 28, 2013, 02:35:29 pm »
If the dealer doesnt have it, or I cant get the viton one at a hydraulic supply then I am gonna order the one you suggested libby.
Reply #9July 28, 2013, 04:06:18 pm
« Reply #9 on: July 28, 2013, 04:06:18 pm »
Reply #10July 29, 2013, 09:13:29 pm
jaed_43725
« Reply #10 on: July 29, 2013, 09:13:29 pm »
Resolved the issue hopefully. I bought the factory o-ring from the dealer. I will pick it up on Wednesday and let everyone know how well it worked.
Reply #11August 02, 2013, 10:07:24 am
jaed_43725
« Reply #11 on: August 02, 2013, 10:07:24 am »
First o-ring was to big. 2nd is correct. But does anyone have the torque spec for the lid? I really need that to get my brakes back.
« Last Edit: August 02, 2013, 11:41:04 am by jaed_43725 »
Reply #12August 02, 2013, 05:16:29 pm
jaed_43725
« Reply #12 on: August 02, 2013, 05:16:29 pm »
Anyone at all know the torque spec?
Reply #13August 02, 2013, 06:41:47 pm
« Reply #13 on: August 02, 2013, 06:41:47 pm »
I just snug em down.
Reply #14August 03, 2013, 05:05:59 am
jaed_43725
« Reply #14 on: August 03, 2013, 05:05:59 am »
I guess I will snug them down and get a measurement off of one and use that for all 3.
