Author Topic: Ticking noise 1.6TD  (Read 12425 times)
July 22, 2013, 08:07:03 am
Brianshayne
  • 33
Ticking noise 1.6TD
« on: July 22, 2013, 08:07:03 am »
Just started... Ticking sound, matches RPM...
Possibilities: I have an inner CV seal that I know is blown -- need to change it. Could it be this?
One of the belts making a sound?
Lifter/internal engine? (Doesn't SOUND like the lifter tick on my old subaru -- not a bearing tick either, as far as I know)
Should I record the sound maybe?
1990 Tornado Red Jetta 1.6TD
Reply #1July 22, 2013, 09:37:22 am
Re: Ticking noise 1.6TD
« Reply #1 on: July 22, 2013, 09:37:22 am »
You can eliminate option #1 (CV) if it still ticks in neutral.
Reply #2July 22, 2013, 09:42:26 am
Brianshayne
  • 33
« Reply #2 on: July 22, 2013, 09:42:26 am »
Yup did that, was about to post. It almost sounds like a gasser injector click? A little more robust though
Reply #3July 22, 2013, 09:54:01 am
Brianshayne
  • 33
« Reply #3 on: July 22, 2013, 09:54:01 am »
Went to go record. No tick.
Reply #4July 22, 2013, 05:43:09 pm
Kudagra
  • 738
    • www.no-coast.com
« Reply #4 on: July 22, 2013, 05:43:09 pm »
ITS FIXED!!
Turbo boost libido and passive restraints
And as of yet I haven't heard even a single complaint
I've got the tools of the trade and a fuel injected heart
Efficiency is beautiful, efficiency is art
Reply #5July 22, 2013, 06:11:12 pm
« Reply #5 on: July 22, 2013, 06:11:12 pm »
I don't want to scare you but that is kind of what my precup did when it was about to fall out. If you notice loss of power up hills then I would bite the bullet and pull the head. If it runs fine then I wouldn't worry. It could just be the advance giving you a nailing sound.
Reply #6July 22, 2013, 07:22:39 pm
« Reply #6 on: July 22, 2013, 07:22:39 pm »
ITS FIXED!!
My boss says this.. He is a douche.. haha.
Reply #7July 23, 2013, 05:57:26 am
Brianshayne
  • 33
Re: Re: Ticking noise 1.6TD
« Reply #7 on: July 23, 2013, 05:57:26 am »
It hasn't been present since this post. Weirrrd
Sent from my SGH-I747 using Tapatalk 2
Reply #8July 25, 2013, 04:52:47 am
« Reply #8 on: July 25, 2013, 04:52:47 am »
ITS FIXED!!
my favorite thing at work is when people say whats wrong with it?  and i just say it's broken.
i am soooooo funny.
Reply #9July 26, 2013, 04:50:18 am
air-cooled or diesel
« Reply #9 on: July 26, 2013, 04:50:18 am »
you have a hydro or mech head? ticking -usually- indicates lifter or exhaust. if you have a mech head and know your way around your engine you may want to check valve lash. even on a hydro looking under valve cover can tell you a couple of things.
Reply #10July 26, 2013, 09:06:23 am
Brianshayne
  • 33
« Reply #10 on: July 26, 2013, 09:06:23 am »
No clue what kind of head.
Reply #11July 26, 2013, 09:06:56 am
Brianshayne
  • 33
« Reply #11 on: July 26, 2013, 09:06:56 am »
Sounded like a sticky lifter actually. Gone now though
Reply #12July 29, 2013, 07:02:24 am
Brianshayne
  • 33
« Reply #12 on: July 29, 2013, 07:02:24 am »
Reply #13July 29, 2013, 07:21:30 am
« Reply #13 on: July 29, 2013, 07:21:30 am »
i couldn't watch/hear video as I didn't want to register on another website,
but a ticking could be exhaust or lifter. if its hydro lifters it could be bad lifter or possibly need fresh oil. if its hydro lifters and lifters/cam lobes look good; if you haven't changed oil in a while, use a good engine oil flush and run at a fast idle(don't drive with flush in oil) and change oil/filter. if you use conventional oil, i use Castrol 10w-30 cj/ch rated. if you use synthetic you'll have to find some good quarts. maybe try a auto/diesel shop, or a german shop. i don't like the rotella, the Castrol is a step or 2 up from rotella.
hopefully this will help.
i think the first thing is to determine if the 'tick' is exhaust or possibly a lifter. and if its a lifter a visual inside valve cover is what i'd start with.
if you change oil use a good filter too. napa has decent filters(air and oil; and good belts too).
Reply #14July 29, 2013, 09:01:24 am
Brianshayne
  • 33
« Reply #14 on: July 29, 2013, 09:01:24 am »
Sorry, I had it set to private. My mistake. Try now.
I'm running 10w-40 Rotella atm. Should I be running a lower weight? The clicking sounds exterior in the video, so maybe belts?
