Author Topic: Air bubbles in the inlet fuel line....??  (Read 3331 times)
March 10, 2006, 04:46:41 am
turbotor
  • 50
« on: March 10, 2006, 04:46:41 am »
When I rev the engine i can see airbubbles in the inlet fuel line from the filter to the pump.....thats not right??
I didnt see this before I made the governour mod....
Reply #1March 10, 2006, 06:38:19 am
regcheeseman
  • 714
« Reply #1 on: March 10, 2006, 06:38:19 am »
pull the white plastic fitting out of the fuel filter, fill the filter with diesel and refit the white plastic fitting.
The bubbles will now clear.  :)
Reply #2March 10, 2006, 07:07:02 am
turbotor
  • 50
« Reply #2 on: March 10, 2006, 07:07:02 am »
Quote from: "regcheeseman"
Thanx, I will try that! :)
Reply #3March 10, 2006, 07:33:14 am
Darkness_is_spreading
  • 288
You may need to replace you fuel filter
« Reply #3 on: March 10, 2006, 07:33:14 am »
If you have cracked the bottom plastic water drain, or the filter is clogged it may be allowing air into the system, it usually a sign of an old filter. Open it up and have a look see, filters are cheap and easy to replace,
*Don't forget to have a full fuel filter, I mean go throughly over this procedure, or you will ge air lock*
92 Jetta 1.6 T (Sleepin)
Reply #4March 11, 2006, 01:04:52 am
  • 2932
fuel filter
« Reply #4 on: March 11, 2006, 01:04:52 am »
I'm guessing fuel filter is clogged because there are only bubles when you rev it.
 A vacuum gauge or switch attached tot he fuel line would let you know the filter was getting clogged (or if that's the problem) way before this happens.
Reply #5March 11, 2006, 04:05:04 am
turbotor
  • 50
« Reply #5 on: March 11, 2006, 04:05:04 am »
Im going to change the filter anyway, to be sure I think.....maybe the valve on top of it too.
Reply #6March 22, 2006, 03:45:54 pm
okron1k
  • 111
« Reply #6 on: March 22, 2006, 03:45:54 pm »
i have seen this problem on my car as well. let me know if the fuel filter change fixed it.
Reply #7March 22, 2006, 03:57:11 pm
wyldman
  • 403
« Reply #7 on: March 22, 2006, 03:57:11 pm »
Usually a fuel filter change will do the trick.Also check the line clamps,and make sure they are tight.
(416)565-7282
Reply #8March 23, 2006, 02:03:50 am
turbotor
  • 50
« Reply #8 on: March 23, 2006, 02:03:50 am »
Yes, changing fuel filter removed the air bubbles!! but I did have a small leak om my pump too.
It made a BIG difference in how car drives!!!! belive me!  :D
