Author Topic: Down Pipe (dp) gasket.  (Read 2083 times)
July 06, 2013, 07:38:25 pm
jaed_43725
« on: July 06, 2013, 07:38:25 pm »
What is the part number either factory or from a manufacturer for the turbo to dp gasket? I have read of people on here using a copper substance in a tube to also make a gasket. Is that a better way to go? Any help is appreciated.
Reply #1July 06, 2013, 08:47:11 pm
akrallysport
Re: Down Pipe (dp) gasket.
« Reply #1 on: July 06, 2013, 08:47:11 pm »
What turbo?
Reply #2July 07, 2013, 06:15:33 am
jaed_43725
« Reply #2 on: July 07, 2013, 06:15:33 am »
K14
Reply #3July 07, 2013, 06:26:47 am
bbob203
  • 1789
« Reply #3 on: July 07, 2013, 06:26:47 am »
not all turbos had the gasket.
92 Passat wagon M-TDi
03 Jetta wagon TDi
VE Timing tools for rent
Reply #4July 07, 2013, 06:52:02 am
jaed_43725
« Reply #4 on: July 07, 2013, 06:52:02 am »
So would a nice clean surface work then? Or is it best to have a gasket or make a gasket?
Reply #5July 07, 2013, 08:16:51 am
Gizmoman
  • 1301
« Reply #5 on: July 07, 2013, 08:16:51 am »
I had a gasket on mine when I took it apart. After a similar discussion here, it seems many don't use one, so I didn't either.
I think Proth sells them but if your surfaces are flat, you should be OK.
I used high-temp silicone on mine but it's not running yet so I can't say if it will work.
