Author Topic: Can't open Caddy tailgate - what a joke!  (Read 15314 times)
July 01, 2013, 05:44:28 pm
92EcoDiesel Jetta
« on: July 01, 2013, 05:44:28 pm »
One of the tailgate handle  rod fell off/ dropped into the abyss due to a broken/ missing nylon insert in the metal rod clip. While taking the handle off to make more room to fish the rod out I managed to drop the other rod!
There is no way to jimmy the two latches! It is well protected! Why??? There is no lock on the tailgate, why design it so you can't jimmy it? Because the rods are at the bottom of narrow (3/4" ) and deep tailgate walls, it is very difficult to get purchase and fish them up.  Finally got them after 1/2 hour trying. VW could have put a catch in the wall to prevent the rods from dropping  to the bottom but didn't. Must be a joke!.
Have a set of clips coming from Ebay.
http://www.ebay.com/itm/Gen-Vw-Rabbit-Pickup-Caddy-Tailgate-Handle-Rod-Clip-/270698961624?pt=Motors_
Car_Truck_Parts_Accessories&hash=item3f06ea5ad8&vxp=mtr
I'll be stuffing some foam in the walls to keep the rods from dropping again.
Anyone else run into this? Not fun!
Reply #1July 01, 2013, 07:42:05 pm
tyb525
  • 183
Re: Can't open Caddy tailgate - what a joke!
« Reply #1 on: July 01, 2013, 07:42:05 pm »
About as good of a design as a rubber belt keeping the valves and pistons from colliding I'd say.
2004 Golf BEW, '81 1.6 NA rabbit (soon to be parted out)
Reply #2July 01, 2013, 07:59:42 pm
« Reply #2 on: July 01, 2013, 07:59:42 pm »
Lol. What is ironic about this is, is that it is stronger than a timing chain ;)
Reply #3July 01, 2013, 08:02:29 pm
DanV990
  • 20
« Reply #3 on: July 01, 2013, 08:02:29 pm »
Show me a 4 stroke OHV diesel that is a non interference motor. Oh wait a second you can't.
« Last Edit: July 01, 2013, 08:11:24 pm by DanV990 »
Reply #4July 01, 2013, 08:08:06 pm
« Reply #4 on: July 01, 2013, 08:08:06 pm »
Only better design to that would be gear-to-gear driven, but even they have a failure rate I am sure..
Reply #5July 01, 2013, 08:09:37 pm
Gizmoman
  • 1301
« Reply #5 on: July 01, 2013, 08:09:37 pm »
One if my recent favorites is putting the cold start cable into the IP linkage - swiveling clamp chingus and tightening the tiny screw - without moving anything ;D
You know- down in the dark abyss between the pump , the injectors and the steel injector lines.
Good idea on the foam.
Reply #6July 01, 2013, 08:16:34 pm
« Reply #6 on: July 01, 2013, 08:16:34 pm »
I do that before the pump gets installed... haha
Reply #7July 01, 2013, 09:37:45 pm
« Reply #7 on: July 01, 2013, 09:37:45 pm »
Gears are better but they transmit more vibration than a belt, so yes you are correct in saying failures. Not as much timing but valve train takes a beating.
As far as the tailgate goes, I don't know what we could do to make it better now that they have it this way. Maybe only service it with it off the truck so you can turn it upside down to dig out the rods?
Reply #8July 02, 2013, 02:06:35 am
81 vw pu
« Reply #8 on: July 02, 2013, 02:06:35 am »
Bingo, that's what I do. I have a special long screwdriver with a 90 on the end to release the latch on each side then pull the tailgate off and flip it upside down so rods fall back into position..
Reply #9July 02, 2013, 05:04:40 am
rs899
  • 647
« Reply #9 on: July 02, 2013, 05:04:40 am »
When I bought my caddy 20 years ago it had holes drilled in the surface side about 2" from each latch.  One inserts a screwdriver in each latch and jimmies.  That's the way I left it...
Reply #10July 02, 2013, 05:18:01 am
92EcoDiesel Jetta
« Reply #10 on: July 02, 2013, 05:18:01 am »
I was wondering if the Bentley says "if the rods drop, flip truck upside down to access rods and release latches to service tailgate"
Reply #11July 02, 2013, 05:21:59 am
92EcoDiesel Jetta
« Reply #11 on: July 02, 2013, 05:21:59 am »
Very curious of this setup. Where do you insert the screwdrivers? How long are they?
I also tried a magnet. Didn't work. All it did was stick to the tailgate walls.
Reply #12July 02, 2013, 09:12:30 am
81 vw pu
« Reply #12 on: July 02, 2013, 09:12:30 am »
If you look straight down between the bed end and tailgate you will see the latch. Insert long skinny flat tip screw driver (8" to 10")  with a short 90 degree angle on tip. You will see hole in the bracket where the spring loaded piece sticks through. Push the plunger back towards the center of tailgate while pulling outward on tailgate. Now repeat on other side if both rods are off.
Reply #13July 02, 2013, 09:30:25 am
92EcoDiesel Jetta
« Reply #13 on: July 02, 2013, 09:30:25 am »
 Thanks, I'll practice that after I get the tailgate back on. Before I do that should I take the latches apart to lubricate? Anything to watch out for if I need to do that?
Reply #14July 02, 2013, 09:47:05 am
92EcoDiesel Jetta
« Reply #14 on: July 02, 2013, 09:47:05 am »
