Author Topic: Vacuum pump sucks oil from crank case  (Read 4807 times)
March 09, 2006, 07:27:55 am
bryanbryan89x
  • 110
« on: March 09, 2006, 07:27:55 am »
My vacuum pump is sucking oil from the crankcase and leaking it all over, it also is ruining the diaphrams.  I have the plastic piece that sits ontop of the cam shaft(people at the parts place told me this could be the cause, maybe they were just trying to sell me something).  Im not sure why it is sucking oil.  If i cant fix it can i remove it?  I have driven the past 20k miles without power brakes due to all the ruined diaphrams, not having them would not bother me.
1981, Rabbit Car, 1.6, N.A.
Reply #1March 09, 2006, 11:52:03 am
toomanycars
  • 68
    • http://www.mathomfarm.com.au
Sucking or blowing???
« Reply #1 on: March 09, 2006, 11:52:03 am »
Are you sure it's not crankcase blowby that's blowing oil into your vac pump? Worn engines will do this especially if they haven't been modded with an extra crankcase breather. (Check out this forum by doing a search for "runaway")
Regards, Peter.
1978 Golf diesel
1984 Nissan Patrol diesel
1986 Toyota Landcruiser 73 series 3B diesel
2006 Golf TDI 2.0 16v
Reply #2March 09, 2006, 02:33:27 pm
bryanbryan89x
  • 110
« Reply #2 on: March 09, 2006, 02:33:27 pm »
thanks toomanycars, i think i found the thread you were talking about,
http://www.vwdiesel.net/phpBB/viewtopic.php?t=1490&postdays=0&postorder=asc&start=15
It does sound like it is my problem, but i have never experienced a run away before.  Im curious did you ever try out the oil sepearator tanks from summit???
Reply #3March 09, 2006, 05:43:41 pm
toomanycars
  • 68
No....
« Reply #3 on: March 09, 2006, 05:43:41 pm »
Didn't need them. I modded the breather and have had no problems since. I recently bought a 1980 Golf diesel that had the factory recall breather fitted. It has a fairly worn engine (poor compression) but it doesn't run away either. If I were you I'd do the modification as when you take the car on a long run at high engine speeds on a warm day I would bet it runs away! Not a pleasant experience!
Regards, Peter.
1978 Golf diesel
