Author Topic: Mk1/2 parts!!!!!! Lots!!! All Best offer! I need $$$! Hah  (Read 4686 times)
June 17, 2013, 07:31:59 pm
Jagerauto
  • 144
« on: June 17, 2013, 07:31:59 pm »
All prices OBO everything must go!!!
1.6TD injector pump came off a quantum with 109k. $250
1.6NA pump good working order nothing wrong with it. $150
Mk1 manual steering $40 for the rack $50 for the knuckle.
I have a box full of coolant res $10ea
I have a box full of motor parts like block caps/seal carriers, oil filter brackets, diesel vac pumps, oil pump ect
Timing covers, valve cover
.75 5th gear set for an 020
1.6td oil pan with matching oil pump and dip stick. This was on a quantum and is irregularly shaped but can be used on any 1.6 with all these parts swapped. $100
1.6 injector pump lines $30/set
1.6d mk1 power steering pump. $20
Mk1 Jetta headlights and grills $100
Box full of motor/trans mounts. I have all except 1.6 diesel passenger mount with ip. Also a few new clutch cables in there.
Mk1 gasser cluster good working order, great cond. 176,876 miles.
Westy wooden dash bezel $40 it had a few imperfections
Bin full of interior parts
Mk1 5speed diesel trans "4S" code. $100 its missing the drive flanges but I have two to go with it.
1.6 injection pump. $50 car ran but had a stuck throttle, needs to be cleaned out.
Box full of random pullies
Reply #1June 20, 2013, 02:52:09 pm
Jagerauto
  • 144
Re: Mk1/2 parts!!!!!! Lots!!! All Best offer! I need $$$! Hah
« Reply #1 on: June 20, 2013, 02:52:09 pm »
ttt
Reply #2July 26, 2013, 10:19:20 am
somolovitch3
  • 290
« Reply #2 on: July 26, 2013, 10:19:20 am »
What are the odds of you having a non AC Alt bracket?
Byte Me, Gently
81 Caddy (Trk)
84 Gti (DumBunny)
Reply #3July 26, 2013, 02:10:01 pm
« Reply #3 on: July 26, 2013, 02:10:01 pm »
The 4S is a mk2 TD tranny used from around 1990-1992
What's the price on the Jetta cluster?
Reply #4July 26, 2013, 08:54:15 pm
« Reply #4 on: July 26, 2013, 08:54:15 pm »
Got a 4S in my 88 German Jetta too.
Reply #5July 29, 2013, 05:03:01 pm
Jagerauto
  • 144
« Reply #5 on: July 29, 2013, 05:03:01 pm »
$40 shipped pm me
Don't sorry
Reply #6July 31, 2013, 02:34:04 am
JASGTi
  • 61
« Reply #6 on: July 31, 2013, 02:34:04 am »
How much for the Westy HVAC controls?
Reply #7July 31, 2013, 05:30:08 am
bbob203
  • 1789
« Reply #7 on: July 31, 2013, 05:30:08 am »
4s is the same as an AGS but with the late style case with the CE2 reverse light.
92 Passat wagon M-TDi
03 Jetta wagon TDi
VE Timing tools for rent
Reply #8July 31, 2013, 07:25:38 pm
Jagerauto
  • 144
« Reply #8 on: July 31, 2013, 07:25:38 pm »
$30 shipped!
