Author Topic: Mk1 Jetta head light issues  (Read 7745 times)
Reply #15June 18, 2013, 05:28:37 pm
homerj1
  • 433
Re: Mk1 Jetta head light issues
« Reply #15 on: June 18, 2013, 05:28:37 pm »
Got the headlights working - just as you guys said, I had to repin the low/high beam. - Thanks
As for grounding the 4 wires at the back of head - for temp gauge etc.  -  a no go.
I grounded each of the four wires one at a time, ( with key on) and nothing happened   either gauge\light-wise-at the instrument panel.
So I guess I have to start my way backwards - wiring, all the way back to the instrument panel.
Reply #16June 18, 2013, 06:44:35 pm
« Reply #16 on: June 18, 2013, 06:44:35 pm »
well just ground them and goto town with the other connections.. at least you play w/one.. turn on key.. see what im sayin.. better then getting uo/down to test..
Reply #17June 19, 2013, 05:49:25 am
shwak23
  • 417
    • Blackdog Junkyard
Re: Re: Mk1 Jetta head light issues
« Reply #17 on: June 19, 2013, 05:49:25 am »
http://item.mobileweb.ebay.com/viewitem?itemId=330730820313&index=22&nav=SEARCH&nid=62002036258
http://www.danielsternlighting.com/tech/relays/relays.html
http://www.carid.com/universal-lighting/putco-acessories-454178.html
These things... are the cheapest but still quality. Get the harness and the lights all at the same time and you wont be sorry. Making a harness.... is bull***. You can't drive to the store, buy wire and relays for less than $30. Buy the housings. The ebay seller I linked too sells a quality product. They aren't HELLA...But wtf does anyone need hella for? His are all glass/metal construction. They are solid. I have some in my golf. Plus... free bulbs....
Sent from Outer Space!
Reply #18June 19, 2013, 08:13:14 am
« Reply #18 on: June 19, 2013, 08:13:14 am »
2 relays... and rear wiring harness from  pre ce2 to build it from.. i reuse harnesses from cars i strip so i got multi colored wires...
