Author Topic: IP plumbing questions  (Read 2633 times)
June 08, 2013, 12:15:06 pm
Gizmoman
  • 1301
« on: June 08, 2013, 12:15:06 pm »
Here's a snapshot of my whammer-jammer Giles pump.
Can anyone tell me if I have the ports labeled correctly?
On the FUEL OUT port (if correct), there is a dual banjo fitting. I am assuming that the smaller barb goes to one of the small barbs on #1 injector. The larger barb goes back to tank.
Also, the barb on top of the LDA (I think that's what it is) - is boost from the turbo. This would be a hose "T'd" from the line going to my DIY boost controller which opens the waste-gate - correct?
Let me know If I have labeled this incorrectly.
Thanks.
Reply #1June 08, 2013, 12:21:36 pm
Re: IP plumbing questions
« Reply #1 on: June 08, 2013, 12:21:36 pm »
Yes.
Reply #2June 08, 2013, 12:43:22 pm
Gizmoman
  • 1301
« Reply #2 on: June 08, 2013, 12:43:22 pm »
Thanks.
Yes.
Yes, incorrect or Yes, correct? hahah
Reply #3June 08, 2013, 01:12:18 pm
« Reply #3 on: June 08, 2013, 01:12:18 pm »
:P
you driving.. me nevogating...
me.. up here turn left...
you... i wanna turn left, right?
me.... right....
you... turn right................................................................
dont overcomplicate...
Reply #4June 08, 2013, 01:44:48 pm
« Reply #4 on: June 08, 2013, 01:44:48 pm »
The only question you asked was, "can anyone tell me?"  Yes, someone can tell you.   :D
You have it labelled correctly.
Reply #5June 08, 2013, 02:00:46 pm
Gizmoman
  • 1301
« Reply #5 on: June 08, 2013, 02:00:46 pm »
I really try hard to explain myself clearly and the harder I try, the muddier it gets ;D
Who's on first?
Thanks for the "correct" answer.
