General Information
User's ride Wall
vr6t
Topic: vr6t (Read 7852 times)
June 02, 2013, 12:54:13 pm
vr6t
June 02, 2013, 12:54:13 pm »
the beginning...
how it arrived
after 6 weeks of backorder ring... dont have me build you a engine w/new rings on deadline... my tdi and this worldwide back orders it seems when ya need a hole of rings... never again do i want such a job... what a pain to install the pistons...
how big is that turbo.... look at the crack pipe beside it...
its build will be here.. if you join..
Check out my Driiive profile
then click the follow, anytime you log in it will tell when i update it.. ill update this thread when major got crap to say... ill do daily pics of tightened this nut there..
how she sits as of today... .yes it stilll runs needed to be able to move it out then back in once engine was inside my shop.. ill finish the engine build.. then gut it down.. swap subframes/from mount set ups.. pedals and then stick the engine/tranny in.. do ic stuff.. then ill dick with rebuilding wiring, ce2 swap.. roddo dash.. so on... i say 2-3 weeks...
i hope my proto engine crap here as ill have 2 weeks to get my 84 ready for madness then..
Last Edit: June 02, 2013, 01:02:04 pm by CRSMP5
June 03, 2013, 09:11:00 pm
Smoker
Re: vr6t
June 03, 2013, 09:11:00 pm »
:drool:
Second to a healthy diesel, the sound of a vr-t gets my blood going.
June 04, 2013, 07:21:44 pm
vwroadkill
Re: vr6t
June 04, 2013, 07:21:44 pm »
you are a lucky dog... I have swapped over 5 vr6's into MK2's they get easier.. my only hope is that you have an early Passat parts car..I do have some stuff at the shop for the conversion if ya cant find it locally...
are you using a OBD1 or a Dizzy for ignition?
new owner of an 81 caddy diesel yipeeeee..vw gti vr6 and well most of gm's trucks
June 04, 2013, 10:21:35 pm
Re: vr6t
June 04, 2013, 10:21:35 pm »
coil pack... have some plug/play harness for programable system... already wired for the mk3 harness plug... i just have to do the ce2 swap..
roddo rad/lower crossmember... b3 pedals.. mk3 subframe with rack and all, rear beam too.. early westy grill set up.. gets cut up for the ic too.. just till fitted no idea how much... gave a friend who has beeninto building custom headers that actually perform the upper plenium so we can size it up for a log.. anc cut it to build one...
but i worried on headgasket/spacer so once again on hold...
June 05, 2013, 07:38:34 pm
vwroadkill
Re: vr6t
June 05, 2013, 07:38:34 pm »
are you using the brake booster bracket? it has the standoffs for the hydro clutch... and as it is a mk2 it should hopefully have the dent already in it for the area that has to be drilled for the actuator. as for head gasket and spacer.. I will ask my buddy which spacer to get.. I use MLS for head gasket..
as for the radiator and fan.. I have a set up at the house..MK3.. if you need it let me know..
hell I have condenser and piping for A/C.. you could have all the luxuries. and power..LOL
let me know If I can help...
as for the spacer... depending on cr you want to run..120 thousands' spacer including the MLS headgasket... what kind of boost do you plan on obtaining? 15..17?
Last Edit: June 10, 2013, 05:57:40 pm by vwroadkill
June 10, 2013, 07:12:45 pm
Re: vr6t
June 10, 2013, 07:12:45 pm »
need AAs.. lol.. camera i guess i left it on..
but had some leafy stuff.. so not any time soon..
tomarrow will have $2 o-ring for timming cover oil feed passage to tensoner... but head on.. thermo/crack pipe installed so on.. chains all set... maybe tomarrow have tranny and all installeed... gotta go get me a "biatch' for a few hr now...
i have pedals/bracket from non abs b3... part of crazymikes 02a swap he did not need.. once i get engine sittin in, rpddo rad.. ill be able to see what i have to fab for this fmic... but right now ill assume cut all metal between headlights up to where 2nd dary latch hangs thru.. hate to poke ic with that.. and build box round ic.. and tie core support to that.. its freggin rediculus..
June 11, 2013, 05:52:48 am
bbob203
Re: vr6t
June 11, 2013, 05:52:48 am »
What is the "crack pipe" for?
92 Passat wagon M-TDi
03 Jetta wagon TDi
VE Timing tools for rent
June 11, 2013, 06:06:53 am
GTiTDi
Schnell Snail TDI performance
Re: vr6t
June 11, 2013, 06:06:53 am »
Quote from: bbob203 on June 11, 2013, 05:52:48 am
91 GTI/ AHU spec'd 1Z power, GT2052W w custom adapter (available through me, PM me for details),TDTUNING software, PP764 nozzles, Massive spearco FMIC, PD intake, Koni reds
97 B4VGLX AHU, RC3, 357's, PP'd head, Shine springs and Koni yellows
June 11, 2013, 12:10:19 pm
Re: vr6t
June 11, 2013, 12:10:19 pm »
right there it is.... understand turbo size now??
freeken $2 o-ring stuck in shipping.. kid you not... truck broke down on way to stealership...
owner came and elbow grease =................................
Last Edit: June 11, 2013, 12:15:21 pm by CRSMP5
June 14, 2013, 12:16:55 pm
Re: vr6t
June 14, 2013, 12:16:55 pm »
June 14, 2013, 03:05:56 pm
Re: vr6t
June 14, 2013, 03:05:56 pm »
Dig the westy 200mm setup.
Round 2
Reply #11
June 19, 2013, 07:46:37 am
Re: vr6t
Reply #11 on:
June 19, 2013, 07:46:37 am »
gots lots of welding to do now...
its going to spit fire so nice... somehow i ended up with a piece of bend left that made up the perfect up swept tip IMO.. 3" from the cat/muffler bolted on head thru the tip..
3 pypes j pipes..
3 v band..
2 4ft sections..
abt 17 hr in fab.. still gotta make mounts/hangers.. then gotta weld all the seams.. can you say $1k exhaust easy... but it no hit..
Reply #12
June 19, 2013, 11:30:30 am
Re:
Reply #12 on:
June 19, 2013, 11:30:30 am »
Idk I think it would almost look better as a turn down than up like that
Sent from my DROID RAZR using Tapatalk 4 Beta
Round 2
Reply #13
June 20, 2013, 11:22:44 am
shwak23
Re: Re: vr6t
Reply #13 on:
June 20, 2013, 11:22:44 am »
Any pics of the exhaust over axle piece. Thats a tough part to fab in my mind.
Sent from Outer Space!
Reply #14
June 20, 2013, 12:44:58 pm
Re: vr6t
Reply #14 on:
June 20, 2013, 12:44:58 pm »
down pipe harder.. ill get a out of car pic once i figure out/tack in the hangers.. then once built and on a lift i can get ya god pic of that area.. but this driiive acct has a few more under car pics.. just crappy as not off ground ver far... jackstands suck..
General Information
User's ride Wall
vr6t
