I know a lot of folks prefer analog tachs but I installed a "tiny-tach" which uses the pulse from one of the steel injector lines - flawless. No moving parts, and several other functions as well. I believe you can even set an alarm. I don't know the upper RPM limit offhand but I'm sure its well over 6,000OK - here's a link http://tinytach.com/diesel.php
If you mount something on the belt cover measuring off the cam, ip or im pulley it can be set up without necessarily needing to weld anything and can be mounted well clear of the belt.
