Author Topic: MK2 Dash Lights -> LED  (Read 5232 times)
May 25, 2013, 07:31:18 pm
« on: May 25, 2013, 07:31:18 pm »
I had the cluster out of my 86td to repair the Temp Gauge and figured "why not"... The stock dash lights are pretty dim - kinda hard to read the trip odo, or fuel gauge.
Most home-improvement stores have 12V strip LEDs, you can get them for cheap online too. (Auto shops seem to charge more.)
They can be trimmed to short lengths, in sets of three emitters:
Some new holes in the top of the cluster to line up with the emitters:
Gaffer's tape holds the strips flat to the cluster:
Hot-glue holds the wires so they don't pull on the flimsy PWB:
Bright enough now, at full intensity
They dim just like the stock bulbs:
I don't intend to run them full-blast, except when checking the trip odo, or at dusk when it requires higher than normal brightness.
Reply #1May 25, 2013, 10:03:37 pm
Re: MK2 Dash Lights -> LED
« Reply #1 on: May 25, 2013, 10:03:37 pm »
Nicely done and worth a sticky I'd say.  Easy mod and no extra resistors or anything.
Reply #2May 26, 2013, 09:28:51 am
« Reply #2 on: May 26, 2013, 09:28:51 am »
the white housing the pcb/bulbs go into.. if your carefull you can pop it off the cluster.. i remove the green piece that filters the white light.. that cures it for most... and i just use glue to put it back into place..
that area you could fill with leds vs on the outside like you did it too..
Reply #3May 26, 2013, 08:49:21 pm
ToddA1
  • 434
« Reply #3 on: May 26, 2013, 08:49:21 pm »
Why not do drop ins?  They're cheap and easy.  I've been using them for years.
-Todd
Reply #4May 26, 2013, 09:02:05 pm
« Reply #4 on: May 26, 2013, 09:02:05 pm »
I got a bunch of this stuff. I'm making courtesy lights, trunk lights, etc...
(Give a guy a hammer and everything looks like a nail, lol.)
