Author Topic: I need help with 92 eco diesel alt. belt  (Read 1869 times)
May 24, 2013, 04:50:34 pm
davidschaffer
  • 1
« on: May 24, 2013, 04:50:34 pm »
I am trying to put on a new alt. belt but can't figure out how to get the a/c pump off/loose.  I have the alternator off and one of the ac bolts but that is as far as I have gotten.  Any write ups or tips are greatly appreciated. Also, how do I post a pic?
Thank you,
David
Reply #1May 24, 2013, 05:20:59 pm
williamtaygan
  • 33
    • Arctic Vegwerks
Re: I need help with 92 eco diesel alt. belt
« Reply #1 on: May 24, 2013, 05:20:59 pm »
IIRC, you loosen the adjusting/idler pulley for the alternator and then between the radiator and the alt bracket you unscrew the adjusting bolts as far as you need it, don't let it drop out though. Then you need to loosen the power steering bracket.  That system is so frustrating, that I took out the 90 and alternator and stuck in a 65 amp with no AC and the star adjusting alternator You will have to loosen many bolts to replace that belt.  Oh, is there also an adjusting bolt under the wires that connect into the AC compressor?  Argh!
1981 1.6 NA Pickup
1982 1.6 NA Westfalia
1990 1.6 NA Jetta (not running)
1991 1.6 eco Jetta
1994 1.6 TD Jetta
