Author Topic: How do I know which 1.5 timing setting to use? There are two  (Read 2930 times)
May 21, 2013, 03:54:46 pm
rumbling_caddy
  • 80
I have a 1.5D engine with the original injection pump.  Not sure where to look for the "yellow dot"
Initial IP timing was set at 1.00mm, but it felt weak.   I bumped it up to 1.20mm and it feels better,
but I'm not sure if Im over doing it.
From Vincent excelling IDI injection timing guide:
    Early Chassis:  (1977-1983)
    1.5l non-turbo 1977-1980                                        0.88 +/- 0.05 mm
    1.5l non-turbo 1980 with yellow dot                         1.15 +/- 0.05 mm
Reply #1May 21, 2013, 04:01:36 pm
Re: How do I know which 1.5 timing setting to use? There are two
« Reply #1 on: May 21, 2013, 04:01:36 pm »
There will be yellow smeared all over the lower timing advance piston cover on the front side of the pump.  It sounds like u have a yellow for pump tho,  what's the part number on it?
Reply #2May 21, 2013, 04:02:38 pm
« Reply #2 on: May 21, 2013, 04:02:38 pm »
If it's not clacking like crazy you got it right. ;D
Reply #3May 21, 2013, 07:49:11 pm
rumbling_caddy
  • 80
« Reply #3 on: May 21, 2013, 07:49:11 pm »
Can't see any yellow paint anywhere but the 1.5D is running better at 1.20 and not clacking like crazu
Reply #4May 22, 2013, 12:35:14 am
  • 2932
« Reply #4 on: May 22, 2013, 12:35:14 am »
Then advance it a little more.
 They are just numbers, might as well scribe a mark and use that as a referance.
Reply #5May 22, 2013, 04:33:26 am
« Reply #5 on: May 22, 2013, 04:33:26 am »
checked an old vw diesel parts thread, and hagar says 107a is the correct number for a yellow dot pump.  and like everyone else says if its running good where u have theres no reason to change.
