Author Topic: Think this will buff out?  (Read 19838 times)
Reply #15May 20, 2013, 10:18:59 pm
Gizmoman
  • 1301
Re: Think this will buff out?
« Reply #15 on: May 20, 2013, 10:18:59 pm »
Very sorry to hear of your mishap.
Come to think if it, mine had a bad injector before it toasted the rings into the piston on #4. My cups never fell out but they were all cracked a bit and #3 was real loose.
Thanks for the boost libby - I'm still at it. As an overview of my investment. . .
Brand new injectors from Giles
Giles built pump
EGT sensor (with an alarm) installed in the manifold
External oil cooler and dual remote filters
No more WVO - just nice clean diesel
custom WAIC
Also additional quick acting sensing of
oil temp
Water temp
Intake air temp (all have settable alarms as well)
Nearly every weekend over the last ten months and daily reading here.
Reply #16May 21, 2013, 06:01:05 am
« Reply #16 on: May 21, 2013, 06:01:05 am »
Yeah bad injector coupled with cracked precups is a bad day. Mine was just plain and simple too hot too fast. The pump would throw the fuel to it and I think the cups grew faster than the head and stayed bigger longer than the head liked. Eventually the head didn't come back down but my precup did.
Reply #17May 21, 2013, 07:00:53 am
Alcaid
  • 549
« Reply #17 on: May 21, 2013, 07:00:53 am »
Try putting an equally old and inefficient turbo on a TDI and drown it with diesel the same way you did here and see if the TDI survives ;)
'10 VW Passat 1.6TDI Highline
Reply #18May 21, 2013, 07:07:58 am
Gizmoman
  • 1301
« Reply #18 on: May 21, 2013, 07:07:58 am »
If a bad injector can ruin the engine so easily, what's the best insurance against having one?
When mine went "bad" it started as a clicking noise which was tough to hear over the rest of the clacking engine. The only reason I knew it was an injector was that it only did it under load - when coasting it stopped (I learned that here).
It started soon after I flipped over to WVO for a while as I was almost out of fuel in the middle of nowhere.
« Last Edit: May 21, 2013, 07:11:03 am by Gizmoman »
Reply #19May 21, 2013, 07:17:45 am
« Reply #19 on: May 21, 2013, 07:17:45 am »
haha!!!  quite true.  now that i have diesel mekken in my news feed on facebook i've seen him post pictures of some di engines that had a bad injector which pissed a hole through the piston.
Reply #20May 21, 2013, 08:03:23 am
« Reply #20 on: May 21, 2013, 08:03:23 am »
A bad injector that holes a piston causes only destroys the piston.  A piece of precup falling in destroys the piston, head, usually bends the rod and sometimes destroys the block or at least causes damage that requires rebore.  On an AAZ the difference is $75 vs. $900-2000.
Reply #21May 21, 2013, 09:09:11 am
wolf_walker
  • 1205
« Reply #21 on: May 21, 2013, 09:09:11 am »
Father used to say, sometimes you get the bear, sometimes the bear gets you...
I bought a pop tester so if I have one crap out I can't blame anyone but me, and whoever made the nozzle.
I'm developing some thoughts on that subject as I play with injectors and nozzles too speaking of which..
Mentat Text Two
Reply #22May 21, 2013, 10:28:57 am
« Reply #22 on: May 21, 2013, 10:28:57 am »
valid point  ;)
Reply #23May 21, 2013, 03:24:29 pm
Whitbread
  • 28
« Reply #23 on: May 21, 2013, 03:24:29 pm »
I was running stock boost and just enough fuel for a light haze at full throttle. I wouldn't call that drowning it in fuel. My ALH with a 12mm pump and 5x.013's nozzles is drowning in fuel; but 65 psi cleans it up nicely ;).
Exactly. And realistically, the only time I've ever seen it happen is when you blow a nozzle tip off. Which I've yet to see happen on a TDI; only on cummins/duramax motors with dual cp3's running 26+kpsi rail pressure with 5x.020+ nozzles.
I'll be sure to post up pics of the AHU swap  :).
02 Jetta ALH TDI, 2260vk+02M
97 B4V ALH TDI, compound turbos + haldex awd
81 Caddy MTDI AHU
07 Arctic Cat 700 turbo diesel
90 Corrado ALH, 02M + haldex in progress
87 K10, Detroit 4-53T with twins
04 BEW going in 91 Ski Challenger boat
Reply #24May 21, 2013, 04:43:58 pm
Gizmoman
  • 1301
« Reply #24 on: May 21, 2013, 04:43:58 pm »
I'd build a bear trap to at least improve the odds;D
Really, couldn't you attach a sensor to each hard-line and monitor something? I spoze a leaky one wouldn't put out much of a signal though and I believe that's what really does the most damage.
Reply #25May 21, 2013, 05:30:04 pm
« Reply #25 on: May 21, 2013, 05:30:04 pm »
You could probably take a reading off the glow plugs.   ;)
Reply #26May 21, 2013, 05:32:38 pm
Gizmoman
  • 1301
« Reply #26 on: May 21, 2013, 05:32:38 pm »
Interesting thought.
They are basically resistors aren't they?
Reply #27May 21, 2013, 06:09:24 pm
wolf_walker
  • 1205
Re: Re: Think this will buff out?
« Reply #27 on: May 21, 2013, 06:09:24 pm »
Service em when the t belt is changed and other than bad luck all is usually well.  I don't remember if VW gave a service interval on injectors.  I bet Mercedes did.
Sent from my SCH-I535 using Tapatalk 2
Mentat Text Two
Reply #28May 21, 2013, 07:02:59 pm
hillfolk'r
  • 1532
« Reply #28 on: May 21, 2013, 07:02:59 pm »
Yea man i hear ya on the tdis. They have so much grunty torque over the idi's.
i literally took my 12mm pump off my idi and put it on my tdi and would rip your head off.
You can only jam so much fuel into that little prechamber whistle before it wants to come out and say hello to your piston. I like the Idis cause they rattle so much at a stop light it makes everyone look. Or the drive thru: sir please turn your truck off.
Yea the Idis are ok and for a mild tweak but  IMO for serious power go to a tdi-m you will stop breaking parts.except 3 or 5 transmissions.start stocking them like cordwood :)
Throttle cables ftw
Reply #29May 21, 2013, 07:34:18 pm
« Reply #29 on: May 21, 2013, 07:34:18 pm »
I'm sure they did I think it's 100k miles tho. But I agree they should at least be tested during a timing belt change.
Andrew. Glow plugs are definitely a good indicator haha.  When my old rabbit used to run away it would eat the whole tip off of each glow plug
