For Sale/Looking For
Parts for Sale/Wanted
FS CE1 Cluster w/ Tach - damaged
Topic: FS CE1 Cluster w/ Tach - damaged (Read 4707 times)
May 13, 2013, 08:52:04 am
May 13, 2013, 08:52:04 am »
I have a Canadian CE1 cluster with a tach. The blue circuit board is damaged and the tach does not work. Some basic wiring should get it working again though. The breaks are obvious. I think the guy working on this car last had a few too many.
I think everything else worked.
Looking for $35 OBO. Don't be shy.
Click for bigger pics
Last Edit: May 28, 2013, 10:31:46 am by burn_your_money
May 13, 2013, 12:05:56 pm
Re: FS CE1 Cluster w/ Tach - damaged
May 13, 2013, 12:05:56 pm »
pcb same as gasser w/tach... they cut tach lead on clock ones...
its also a ideal canadate to use in vanagon or mod to fit a german mk1 cluster(jetta/cabby)..
May 13, 2013, 02:39:00 pm
May 13, 2013, 02:39:00 pm »
Thanks for the info.
May 15, 2013, 08:12:58 pm
Syncroincity
May 15, 2013, 08:12:58 pm »
Post it on thesamba.com in the Vanagon parts section, someone will jump on it for the tach.
JC McCavitt
'86 Syncro GL Camper AAZ
'98 Jetta Wolfie
May 28, 2013, 10:24:34 am
zolorin
User+
May 28, 2013, 10:24:34 am »
PM sent
1981 vw diesel rabbit pickup
(85 or 86 motor)
June 02, 2013, 01:24:00 pm
big swifty
Newbie
June 02, 2013, 01:24:00 pm »
Still have it? Mine if so.
1991 Jetta Coupe
//1.6 TurboDeezil//
Intercooled
// Pump mods//
1987 Vanagon Syncro TDI
... Westfalia pop-top graft//
RC2
//PP520's
VAG COM
