Author Topic: FS 1.6 TD Parts  (Read 4341 times)
May 09, 2013, 09:57:44 pm
mcpook
  • 59
FS 1.6 TD Parts
« on: May 09, 2013, 09:57:44 pm »
Long time lurker here.  This site has been a wealth of knowledge for me through my v-dub adventures.  Thanks all.  Over the years I acquired some spare parts.  Many of these parts were included as a lot when I purchased a 1.6TD motor for rebuild.  The guy I bought the block from threw in pretty much all the old VW parts he had.  I took the rebuild in a different direction than he had planned, thus I’m listing extra parts here in hopes of funding the rest of the build.  And passing them on to those who could use them. :) I have shipping included in many of the prices which assumes USPS to the lower 48.  Canada/Alaska/Mexico and the likes will likely require a bit extra to cover those locations.
1)   1.6 TD Head.  12mm bolt. Mechanical.  .004” resurfaced.  New valve stems, seals, guides. ~1,000 miles on resurfaced rebuild. Turns out the head wasn't the problem--it was the bad block. Receipt showing recent warpage check pictured. Receipt of machine shop who performed resurfacing also shown.  UPDATE 5/15/2013: I just checked the threads of the glowplugs and injectors and found some damage to the #3 injector seat.  I don't know if this makes this head unusable.  Pic added.  Best offer at this point assuming it's still usuable.
2)   1.9 TD Head.  Bare.  Hydraulic.  Prothe/Rothenbacher Engineering.  Unused in open box.  $225 shipped.
3)   1.6 TD Piston Set.  .5mm over.  Prothe/Rothenbacher Engineering.  Came installed on block I purchased for a rebuild.  Never fired.  I removed and replaced w/ Kolbenschmidts.  Pics show Kolbenschmidt wrapping and box.  These are NOT KOLBENSCHMIDT pistons.  $150 shipped.  SOLD
4)   Recaro Power Seat Bases.  I was told these worked when I bought them.  Sported them in the truck for awhile, but having no power to them made them difficult to adjust.  So I modified some mk2 scirrocco seat bases to carry my recaros.  The are now adjustable and much lighter and sit about the same height.  $100 plus shipping.
5)   Volvo 2.4TD Intake Manifold.  I bought this with intentions of cutting off two runners and creating a custom intake for my engine build. I ended up figuring out how to use a G60 intake w/o hitting the turbo.   $75 shipped
6)   1.6 TD Intake Manifold.  Complete w/ BOV and elbows.  $50 shipped  SOLD
7)   1.9 TD Intake Manifold. $30 shipped  SALE PENDING
8)   1.8 Gasser Intake Manifold.  $40 shipped
9)   Exhaust Manifold.  Unused. www.dieselvw.com cast into it.  Website no longer valid, so you know it’s quality stuff. ;)  $60 shipped
10)   Turbo Downpipes.  $50 each shipped.  I’ll throw in a set of exhaust spring clips.  1 Set SOLD
11)   Windage Tray (Oil Pan Gasket w/ Baffle)  New never opened. $10 plus shipping  SALE PENDING
12)   1.6 TD Valve Cover $10 plus shipping
13)   Headlight Buckets  $20 shipped
14)   Armrests.  $20 shipped
15)   AC Compressor  The remaining parts on the list came as a package with a block I bought for rebuilding.  Don’t know much about them. Not sure if it works.   $50 shipped.
16)   Gasser distributers.  Not sure if they work.  $10 each shipped
17)   Gasser Starter.  Not sure if it works.  Free.  Pay for shipping
18)   Miscellaneous parts.  Free with purchase of other parts.  Just let me know what you can put to use.
pics can be viewed here:  http://mcpook.imgur.com/all/   or    here:   http://imgur.com/a/mZ9xR
« Last Edit: May 21, 2013, 07:50:27 am by mcpook »
1982 Rabbit Pickup 1.6 TD
1996 Passat B4V TDI
Reply #1May 10, 2013, 08:44:04 am
wut_cel
  • 34
Re: 1.6 TD Parts
« Reply #1 on: May 10, 2013, 08:44:04 am »
I'm looking for the intake elbow that comes off the turbo, do you happen to have one?
Reply #2May 10, 2013, 08:54:54 am
mcpook
  • 59
Re: 1.6 TD Parts
« Reply #2 on: May 10, 2013, 08:54:54 am »
Like the rubber one pictured as part of the 1.6 TD intake?  I'll look around tonight in some spare parts boxes to see if anything turns up.
1996 Passat B4V TDI
Reply #3May 10, 2013, 04:26:40 pm
Re: 1.6 TD Parts
« Reply #3 on: May 10, 2013, 04:26:40 pm »
What he's looking for is the metal elbow that bolts to the top of the intake manifold with 2 bolts, and he probably needs the hose that connects it to the turbo as well.
I know this because it's for a car I sold recently.
Reply #4May 12, 2013, 02:30:29 pm
wut_cel
  • 34
Re: 1.6 TD Parts
« Reply #4 on: May 12, 2013, 02:30:29 pm »
Any luck?
Reply #5May 13, 2013, 09:21:07 am
mcpook
  • 59
Re: 1.6 TD Parts
« Reply #5 on: May 13, 2013, 09:21:07 am »
No Luck.  Sorry.
1996 Passat B4V TDI
Reply #6May 15, 2013, 07:39:59 pm
brandnwname
  • 9
Re: FS 1.6 TD Parts
« Reply #6 on: May 15, 2013, 07:39:59 pm »
pm sent
