General Information
General
Where to find grease caps that actually fit
Topic: Where to find grease caps that actually fit (Read 4691 times)
May 08, 2013, 05:55:56 pm
srgtlord
May 08, 2013, 05:55:56 pm »
So thinking back to 4 years ago when I purchased a replacement grease cap for my rear wheel bearing I ordered 2 from partsplace inc. What I received now was a crappy repackaged set of MEYLE grease caps that are machined to the wrong size. Is there anywhere I can purchase a set that will fit?
May 08, 2013, 09:59:38 pm
Re: Where to find grease caps that actually fit
May 08, 2013, 09:59:38 pm »
PartsPlace isn't the only game in town. There's Germanautoparts.com, azautohaus, gowestyautoparts.com, which I really like, rockauto.com and I think a NAPA would probably have them. Just don't order Meyle. I've also noticed their quality isn't what it used to be.
May 09, 2013, 04:10:35 am
srgtlord
May 09, 2013, 04:10:35 am »
I noticed the grease caps at german autoparts is the exact same coloring as the meyle ones....Napa only has the MEyle bearing kit, and gowesty only has FAG bearing kit. I ended up ordering FAG bearing kit from pelicanparts.com. Lesson learned, when ordering wheel bearings, order a kit or waste time...
May 09, 2013, 04:45:49 am
May 09, 2013, 04:45:49 am »
i got mine from napa i think they were the meyle ones, they were a tight fit and i fight each side for a few minutes but they eventually went on.
May 09, 2013, 12:23:13 pm
Moderator
4552
May 09, 2013, 12:23:13 pm »
I picked up kits for the rear wheels a couple of years ago. One cap was tight and I need to run a file around the outer edge to get it to bite enough to tap it home. The other was loose so I had to widen it by tapping it over the ball part of a ball peen hammer. Yes it is the 2 pounder one. Flared it enough to get it to grab and stay.
Can't trust anyone these days.
May 17, 2013, 04:26:49 am
srgtlord
May 17, 2013, 04:26:49 am »
For those who are curious the grease caps in the FAG wheel bearing kit fit perfectly
May 17, 2013, 04:59:54 am
bbob203
May 17, 2013, 04:59:54 am »
I always wanted to find some for the front.
92 Passat wagon M-TDi
03 Jetta wagon TDi
VE Timing tools for rent
May 17, 2013, 05:26:00 pm
Moderator
4552
May 17, 2013, 05:26:00 pm »
Why? Rust? spray with WD40 and you will be fine. No need to cap them
General Information
General
