re-using stretch big end bolts
Topic: re-using stretch big end bolts (Read 2631 times)
April 23, 2013, 01:25:09 am
dave friday
April 23, 2013, 01:25:09 am »
What do you lot do? one engine re-builder in the UK re-uses them 33ftlbs+locktite.
Stretch bolts are no longer available from VW here in Spain!!
1992 1600 td syncro camper
April 23, 2013, 02:53:21 am
wil892
Re: re-using stretch big end bolts
April 23, 2013, 02:53:21 am »
The stretch bolts are the same as used in the G60 petrol engines. I sourced mine from a FEBI distributor, the FEBI part number is 02124
1991 Golf MK2 GTD
April 23, 2013, 05:17:51 am
April 23, 2013, 05:17:51 am »
i used arp bolts because they are the same price.
April 23, 2013, 05:26:23 am
dave friday
April 23, 2013, 05:26:23 am »
Thanks both,usefull info,ive got some on order from "Gunsel"[Germany].
I wondered what people did when replacing bigend bearings?.
April 23, 2013, 06:05:31 am
April 23, 2013, 06:05:31 am »
what engine?? the 1.6 did not have strech.. the 1.9 do and same as tdi from what i read..
the 1.8 gassers have a streach type of stud with goofy nuts.. the nuts have a groove/line down the flat sides..
April 23, 2013, 06:42:07 am
dave friday
April 23, 2013, 06:42:07 am »
well mine does [ 1992 jx 1588cc td]
April 23, 2013, 11:39:18 am
rallydiesel
April 23, 2013, 11:39:18 am »
Later 1.6 were stretch. I believe some of the early 1.6 were not. In any case, most people have reused them without problems, including me. Ideally it would be best to get new ones or ARP's.
1991 Jetta TD - sold
2001 Golf TDI - Son's
April 24, 2013, 12:25:26 am
dave friday
April 24, 2013, 12:25:26 am »
Rally,when you re-use stretch bolts how and what do you tighten them to?.
Ta.
