Author Topic: 1986 4dr Golf with recently rebuilt TD FS ------Needs Love!! SOLD  (Read 7651 times)
April 22, 2013, 07:21:37 pm
mtnbob
  • 738
SOLD_SOLD_SOLD
  Solid Body- Zero Rust on 99.8% of the car. Tiny rust spots at the bottom of one door. I sprayed them with rust convertor when I got the car 5 years ago and they haven't changed. Some rust was under the battery, but sprayed with rust convertor and is solid.
  True TD engine that was bored out to second oversize and fitted with All German top notch parts. Crank was polished. Block was cleaned and painted.
  Engine has new glow plugs and injectors along with a "pimp your glow plug setup" that makes the glow plugs work much better.
  Car starts right up when cold. Started up fine in 20 degree weather.
  Battery is 6 mths old and is 880 CCA Duracell
  Alternator was rebuilt to new specs at a Bosch Authorized Shop
  New steering rack and tie rods installed with rebuild
  New clutch installed
  New A/C Compressor installed but not hooked up
  All new german gasket set used
  Momo Steering Wheel
  Recaro Orthopedic seat in rough shape, but fixable
  Diesel Speedometer with Tachometer
  Oil pressure gauge with copper lines
  Upgraded springs with new struts about two years ago
  Driven over 6months/ 5,000 miles on the engine rebuild
  Interior of car is decent. No cracks in the dash and headliner has a few, but is useable.
  Decent tires and brakes.
  This car was my daily driver until the clutch issues derailed me.
The Bad:
  Something is wrong with the clutch. Possibly the throwout bearing is bad. I can not shift into gear when the car is running.
  The oil pan is missing 2-3 bolts that need to be tapped out and rethreaded.
  There is a moderate oil leak that appears to be coming from the oil pan.
  It has also been mentioned to me that the rear main seal may not have seated properly causing the oil leak and also possibly contributing to the clutch issue.
  Due to the clutch issues, the car must be towed. I considered taking off the transmission and fixing the problems myself, but due to working 3 jobs, I don't have the time to do it. It may be a very easy fix, or it may require the tranny to be pulled and the throwout bearing replaced. Still an awesome, very rare in the states engine, that runs great, with a TD injection pump that is purring away.
Seeking $2,000
Pollen covered car pics below on my Flickr account. I also have a movie of car starting cold, but not able to u/l it right now due to lack of bandwidth
http://www.flickr.com/photos/11904434@N05/sets/72157633304232089/#
Any questions? Ask away. Much time and energy was poured into this car, and it would be cool to see someone with more time than me, fix it and enjoy it.
« Last Edit: September 17, 2013, 07:14:22 pm by mtnbob »
96 Subaru Outback Wagon
Reply #1April 23, 2013, 10:41:59 am
bbob203
  • 1789
Re: 1986 4dr Golf with true TD FS ------Needs Love!!
« Reply #1 on: April 23, 2013, 10:41:59 am »
Dude I would/could fix it for the cost of gas/driving and labor(wouldnt charge an unreasonable amount). im only 5 hours away. think about it. i bet i could have it fixed up in 2 days if that.
92 Passat wagon M-TDi
03 Jetta wagon TDi
VE Timing tools for rent
Reply #2April 23, 2013, 01:04:49 pm
« Reply #2 on: April 23, 2013, 01:04:49 pm »
bbob.. in backyard.. 8hr max... just you gotts remove the pass side flange from tranny or you will fight it..
i myself think 6hr.. + pulling vac pump.. use drill to check his rear main seal when apart.. and fix if it leaks.. 250+parts+tip for backyard work/fuel
i can do 4hr ish in a garage w/concrete floor.... hate dirt/rock/grass.. but sheet of osb..
Reply #3April 23, 2013, 05:17:50 pm
mtnbob
  • 738
« Reply #3 on: April 23, 2013, 05:17:50 pm »
This car has been a labor of love over the last 5 years, but I have to find it a good home and pay for my education!!!  I currently work Special Ed full time and have two part-time jobs. My girlfriend made me a deal on her old car that I couldn't pass up.
 I will be back to diesel as soon as possible, but I have to get a better job first!!!
My Golf is currently under my carport with concrete slab. I have an engine hoist, floor jack, and assorted tools. I am open to reasonable deals. Whoever gets this car will be getting it for thousands less than I have in it.
I also have extra engine parts from 1.6 D
Reply #4April 23, 2013, 06:03:47 pm
bbob203
  • 1789
« Reply #4 on: April 23, 2013, 06:03:47 pm »
if i had the money id probably take it off your hands.
03 Jetta wagon TDi
Reply #5April 23, 2013, 06:34:09 pm
mtnbob
  • 738
« Reply #5 on: April 23, 2013, 06:34:09 pm »
If I had the money, I'd have you help me fix it!! ;D
« Last Edit: April 23, 2013, 10:16:07 pm by mtnbob »
Reply #6April 24, 2013, 06:38:09 am
« Reply #6 on: April 24, 2013, 06:38:09 am »
well who ever buys it knows this... bbob will go with you.. install/fix so you can drive home.. :D screw trailer/dolly that way.. may be easier sell too.. i was not offering my service.. just giving a idea of how id do it if i were a moble mechanic that went cross country working on cars... retirement plans.. :P
Reply #7April 24, 2013, 06:56:56 am
mtnbob
  • 738
« Reply #7 on: April 24, 2013, 06:56:56 am »
It is still far closer than my having to get the TD block from Tyler in Canada!!! ;D
Reply #8April 26, 2013, 05:57:01 pm
shwak23
  • 417
    • Blackdog Junkyard
Re: Re: 1986 4dr Golf with true TD FS ------Needs Love!! $2,800
« Reply #8 on: April 26, 2013, 05:57:01 pm »
Damn your girl is cheap eh? Making you pay for her old car? If I were you I would just "borrow" it. She can take care of registration and insurance. Lol. Tell her you are keeping it fresh and running right. Meanwhile you can keep pumping the money you saved into your VW. LOL.
Sent from Outer Space!
Reply #9April 28, 2013, 09:20:45 am
mtnbob
  • 738
Re: 1986 4dr Golf with true TD FS ------Needs Love!! $2,600 OBO
« Reply #9 on: April 28, 2013, 09:20:45 am »
Price drop Bump ;D
« Last Edit: April 30, 2013, 12:03:12 pm by mtnbob »
Reply #10April 30, 2013, 12:02:18 pm
mtnbob
  • 738
« Reply #10 on: April 30, 2013, 12:02:18 pm »
How low will it go? Bump :o
Reply #11May 01, 2013, 11:34:11 am
« Reply #11 on: May 01, 2013, 11:34:11 am »
for this kinda cash, you might have better luck parting the car out..
Reply #12May 01, 2013, 08:55:50 pm
mtnbob
  • 738
« Reply #12 on: May 01, 2013, 08:55:50 pm »
I know, but I don't really have the time to do it :(
Reply #13May 03, 2013, 03:44:36 pm
mtnbob
  • 738
Re: 1986 4dr Golf with true TD FS ------Needs Love!! $2,500 OBO
« Reply #13 on: May 03, 2013, 03:44:36 pm »
Price Drop Bump!!
Reply #14May 03, 2013, 04:20:20 pm
bbob203
  • 1789
« Reply #14 on: May 03, 2013, 04:20:20 pm »
id ebay it man.
03 Jetta wagon TDi
