Deciding on parts for my turbo setup
Pages:
Topic: Deciding on parts for my turbo setup (Read 8428 times)
Reply #15
April 12, 2013, 07:24:18 am
Rock3tman
prev: 60typ2, 68pickup, 79rabbitD. now: 83jettaTD
Re: Deciding on parts for my turbo setup
Reply #15 on:
April 12, 2013, 07:24:18 am »
just guessing, I'd say the donor Saab was sometime from late '80s thru '90s - - sorry i can't be more precise.
I'll try to post a photo later today.
Reply #16
April 17, 2013, 07:50:19 am
Rock3tman
Reply #16 on:
April 17, 2013, 07:50:19 am »
photo showing saab downpipe adapted to VNT-15 for MK1 use; note clearance to shift linkage
Reply #17
April 17, 2013, 03:28:22 pm
Rising
Re: Re: Deciding on parts for my turbo setup
Reply #17 on:
April 17, 2013, 03:28:22 pm »
That looks great! I'll have to peak around some yards and see what is out there!
Sent from my ThunderBolt using Tapatalk 2
'84 Rabbit Diesel- 1.6D Stock
Reply #18
May 23, 2013, 03:16:20 pm
Rising
Reply #18 on:
May 23, 2013, 03:16:20 pm »
Quick question: What size piping was that saab pipe?
Because i'm looking online
here
, and the flange appears to only have a 1.90" diameter hole. I'm wondering how big of an output the vnt exhaust housing is anyway?
Is there any advantage to running a 2.5" downpipe on a turbo that only has a 1.90" output flange? Or should I just run 2" downpipe?
Reply #19
July 16, 2013, 08:15:52 am
Rising
Reply #19 on:
July 16, 2013, 08:15:52 am »
http://www.ebay.com/itm/Billet-Alumimum-Turbo-Oil-Return-Flange-10-AN-Garrett-T3-T4-T04B-T04E-T04S-/380666727043?pt=Motors_Car_Truck_Parts_Accessories&hash=item58a1814a83&vxp=mtr
after poking around I think I can pick one of these up and use it to fab a return line (i can't find a stock vnt return line for cheaper than about 70 bucks and I'm just going to have to tear it to pieces anyway). I was thinking with that and a few feet of braided -10 an oil hose I'd be in business. Anybody know if this will work?
http://www.ebay.com/itm/121096762038
http://www.ebay.com/itm/121092409135
http://www.ebay.com/itm/121094084545
Then have a 10an fitting welded to the oil pan?
Reply #20
July 17, 2013, 09:38:32 am
Rock3tman
Reply #20 on:
July 17, 2013, 09:38:32 am »
I think your plan for using -10AN fittings will work well; I used a stock TD oil pan, then had a short section of 16mm steel tubing welded to a male JIC fitting on one end and a compression fitting to mimic stock on the lower end. Then I attached a short braided stainless sheathed teflon hose with female JIC fitting on lower end and a open top end slid over an aluminum barbed fitting bolted to the VNT-15 oil drain area.
Reply #21
July 18, 2013, 05:29:07 pm
Rising
Reply #21 on:
July 18, 2013, 05:29:07 pm »
Excellent ! I think I'm getting closer with all this. Is there any reason I should use jic fittings or barbed fittings over the an fittings? Seems the aN hose and fittings are abundant on fleabay and good prices.
Thinking about doing this for the pan. Is there enough clearance for this ? I'm trying to eliminate as much welding as possible. As welding is going to cost me!
http://www.d-series.org/forums/diy-forum/121599-diy-oil-pan-tapping-oil-return-line.html
Sent from my ADR6400L using Tapatalk 2
Reply #22
July 18, 2013, 05:43:39 pm
Reply #22 on:
July 18, 2013, 05:43:39 pm »
The AN are mostly aluminum and IMHO junk. They are the exact same threads as JIC Exactly a 37.5 degree flare and the number designates how many 16ths of an inch it is. Example an-10 or JIC-10 is a 5/8 or 10/16 sized hose. I like the JIC as the steel ones I have are very reusable.
I think the pan idea would work. I welded mine as I didn't want the chance of vibrations letting it come loose. One major thing I recommend is using a 90 out of the pan. On mkii angled approx. to the freeze plug by #4.
Round 2
Reply #23
July 19, 2013, 09:11:26 am
Rising
Reply #23 on:
July 19, 2013, 09:11:26 am »
Perfect! You're the man
That's exactly the input I needed. I'm still such a newbie with all this fabrication stuff. Theory I understand but how to actually build custom pieces I'm working on.
I looked up jic fittings and it seems hydraulic surplus stores sell them very reasonably. And I'd only need like 2. I'll be sure to take pictures of all of this together once I get it going.
Also found a huge 2" pipe nipple at work that may get jb welded onto a plate for my intake adapter.
Pages:
