Author Topic: 1.5 vacuum pump swap  (Read 5610 times)
March 31, 2013, 03:15:51 am
morgoon
  • 60
« on: March 31, 2013, 03:15:51 am »
I have a 1.5D with no vac pump that I got from a friend, he gave the vac pump to someone before I got the motor.
The original came with the curly q early style style pump.
I'd like to put in an early (81) 1.6 oil/vac pump matched set that I have, and swap out the oil filter housing to get rid of the curly q supply line?
Are there IM shaft differences between the 1.5/1.6  that would prevent this?
Reply #1March 31, 2013, 04:00:09 pm
JamesT
  • 151
Re: 1.5 vacuum pump swap
« Reply #1 on: March 31, 2013, 04:00:09 pm »
No.
93 Golf - AAZ with some fueling
78 Rabbit - 1.5 DIESEL (finally)
[(+)===o===(+)]
 (++\==o==/++)
Reply #2April 01, 2013, 08:58:47 am
« Reply #2 on: April 01, 2013, 08:58:47 am »
I seem to recall a thread on here a while back talking about the differences between oil pump drives (which is what the vac pump engages to) on the 1.5 vs 1.6... Something about the length being different.  I don't recall if it was the actual oil pump drive or if it would affect the vac pump in any way.  Would be worth finding...
Reply #3April 01, 2013, 09:34:13 am
morgoon
  • 60
« Reply #3 on: April 01, 2013, 09:34:13 am »
I think I know the post you are thinking of ...With the three pumps laid flat on a table to look at their drive ends.
I have a matched set of both the early 1.6 diaphragm and the later vane type. (I think that is how they are referred to)
I'll clean and inspect the oil pump and put a matched set in.
Thanks
Reply #4April 01, 2013, 08:44:03 pm
  • 2931
« Reply #4 on: April 01, 2013, 08:44:03 pm »
I don't think the difference was between the early 1.6 and later 1.6.
 I think the curly-q ones had a different oil pump because one supplies oil through the curly tube and one through the shaft of the oil pump,..
oil pump shaft length is different.
Reply #5April 02, 2013, 07:32:57 pm
morgoon
  • 60
« Reply #5 on: April 02, 2013, 07:32:57 pm »
I never seem to explain myself well on here ;D
Fatmobile, I know you know your stuff for sure :)
I was trying to mention two kinds of vac pumps (early 1.6 diaphragm and the later vane type)
And the 1.5 oil/vac pump being different for sure
Reply #6April 03, 2013, 07:56:39 pm
morgoon
  • 60
Re: 1.5 vacuum pump swap..pics added
« Reply #6 on: April 03, 2013, 07:56:39 pm »
Ok so last night I pulled apart the old 11mm 1.6D and found this on the oil pump pick up screen
Then I realized I should have looked at the spline of the oil pump before I went to the trouble to pull it
and the Vacuum pump
So I pulled an oil pump and vac pump from another later 1.6 I had.
Looking pretty clean so far and the slot/spline ends of each look pretty good.
I was wondering if the newer style oil pump with the baffle on it work with the 1.5 oil pan?..I haven't had time to try it yet
« Last Edit: April 03, 2013, 07:58:49 pm by morgoon »
Reply #7April 04, 2013, 08:33:30 pm
  • 2931
« Reply #7 on: April 04, 2013, 08:33:30 pm »
When the oil pump blade and vacuum pump slot starts to wear like that it shoves the gear upward,
 wearing it's way into the brass thrust bearing on the bottom of the vacuum pump.
 If they shove far enough apart they will stop engaging and screech as the oil ight comes on.
Vane pumps don't have a brass thrust bushing.
 Both styles have a seal inside the gear
 that seals around the oil pump shaft.
   It's often black and brittle
 and often mistaken for metal.
 And to answer part of your original question.
 You can't use a 1.5 I-shaft in a 1.6,..
 but it has nothing to do with the vacuum pump.
 The 1.6 crank hits the 1.5 gear because it doesn't have the corner cut off.
Reply #8April 05, 2013, 03:39:33 pm
morgoon
  • 60
« Reply #8 on: April 05, 2013, 03:39:33 pm »
Thank you for the info
I searched and found a thread with that seal part no.
Guess that will be next
Reply #9April 05, 2013, 06:41:06 pm
« Reply #9 on: April 05, 2013, 06:41:06 pm »
idk if you already got your answer, but you need to change the oil pump AND vacuum pump..
i would use a 1.6TD oil pump and vac pump..
Reply #10April 05, 2013, 09:09:14 pm
morgoon
  • 60
« Reply #10 on: April 05, 2013, 09:09:14 pm »
I'm going to use the set on the wooden table in the above photo
On my phone just now or I would just repost it.
I will be using the matching set of pumps from a 1.6d non turbo for now
Tracking down the vane pump rebuild thread now:
Looks like this is the seal number for the vane pump
A 2011 post on another site says: "VW part number #068 145 117 B
Quantities limited in North America.....get 'em while you can!"
I haven't tried to order one yet though
Reply #11April 06, 2013, 08:20:30 am
morgoon
  • 60
« Reply #11 on: April 06, 2013, 08:20:30 am »
Our local VW parts dept doesn't stock the vac pump seal anymore
Does anyone have cross reference part number for it ?
