Author Topic: Need a sanity check US to CE2 wiring  (Read 7604 times)
March 26, 2013, 12:51:32 am
jhax
  • 328
« on: March 26, 2013, 12:51:32 am »
Alright so I have my pin swapping charts done and I would like a sanity check just to make sure the car will start once im done swapping everything over. All US wiring has been acquired from http://www.autolib.diakom.ru/CAR/Volkswagen/1987/Golf/WIRING%20DIAGRAMS/ and all ce2 info comes from http://www.a2resource.com/electrical/CE2.html
US Gauge cluster to CE2 plugs on back of fuse box
US engine bay sensors etc to CE2 plugs on back of fuse panel
Reply #1March 26, 2013, 07:05:16 pm
Re: Need a sanity check US to CE2 wiring
« Reply #1 on: March 26, 2013, 07:05:16 pm »
for a mk2 golf?? id go find later 89-92 and just swap it all.. easier then splicing... but engine so on helps.. no cluewhat your trying to do or what too...
Reply #2March 26, 2013, 11:38:05 pm
jhax
  • 328
« Reply #2 on: March 26, 2013, 11:38:05 pm »
nah ill stick with my traditional westy, Im in the process of building a monster tdi, I will swap the car to ce2 and once the engine is built i will swap the mk4 wiring harness to the CE2 system. No splicing here, pin swapping all the way. The diagrams above are the wires needed to swap the current engine and instrument panel into the CE2 fusebox.
Reply #3March 27, 2013, 08:41:52 am
bbob203
  • 1789
« Reply #3 on: March 27, 2013, 08:41:52 am »
A2resource.com.       May help you.
92 Passat wagon M-TDi
03 Jetta wagon TDi
VE Timing tools for rent
Reply #4March 27, 2013, 12:55:04 pm
jhax
  • 328
« Reply #4 on: March 27, 2013, 12:55:04 pm »
yes i have used that hence the link to a2 resource, i am looking for someone (preferably someone who has done this particular swap before) to double check the charts i made
