Author Topic: wtb Looking for an Audi 5cyl 5 cyl Turbo Diesel Head 2.0L  (Read 3542 times)
March 21, 2013, 09:30:26 am
VW
  • 64
« on: March 21, 2013, 09:30:26 am »
Looking for a good usable head for a 1982 Audi/VW 5000 5 cylinder turbo diesel. Discovered mine has cracks when I pulled it to replace the Head Gasket. Thanks, VW
« Last Edit: March 21, 2013, 09:37:57 am by VW »
Reply #1March 21, 2013, 08:45:04 pm
rabbid79
  • 684
Re: wtb Looking for an Audi 5cyl 5 cyl Turbo Diesel Head 2.0L
« Reply #1 on: March 21, 2013, 08:45:04 pm »
Where are the cracks, and how big?  Small ones between the valves are normal.  Almost any used head you find will also have cracks between the valves.
You can also use a head from an '80-'81 naturally aspirated 5-cyl diesel, just need to drill out the bolt holes and the washer recesses by 1mm.  There are more of these NA heads around than the TDs.
'15 WRX
Reply #2March 22, 2013, 09:25:04 am
VW
  • 64
« Reply #2 on: March 22, 2013, 09:25:04 am »
Yes, there are cracks between the valves and one from the injector port to the valve. I was going to have the head welded up if I can't seem to find a replacement. Thanks
Reply #3April 30, 2013, 06:13:21 pm
VWinA
  • 9
« Reply #3 on: April 30, 2013, 06:13:21 pm »
I can sell you a complete engine with a good head for $500.
