Author Topic: Fuel leak  (Read 3585 times)
March 17, 2013, 07:31:12 am
mattrose87
  • 21
Fuel leak
« on: March 17, 2013, 07:31:12 am »
On the injector lines fuel is spraying out between the line and the injector nut. Are they orings or seals I can replace, or do I have to get new lines all together
I have tried breaking them loose and snugging them back still leaks
Reply #1March 17, 2013, 08:06:04 am
Re: Fuel leak
« Reply #1 on: March 17, 2013, 08:06:04 am »
buy new hard line. I would take it off and inspect first, something could be messed with the sealing surface and it be ok. The hardlines usually go when someone moves the pump but doesn't take the tension out of the hardlines loosening them up.
Reply #2March 17, 2013, 10:48:09 am
mattrose87
  • 21
Re: Fuel leak
« Reply #2 on: March 17, 2013, 10:48:09 am »
Hey thanks alot
