Author Topic: Block heater question and bolt needed  (Read 15604 times)
Reply #45April 28, 2013, 11:14:57 am
hillfolk'r
  • 1532
Re: Block heater question and bolt needed
« Reply #45 on: April 28, 2013, 11:14:57 am »
A different block is gonna have a different crush pattern. So you are back to a new wear pattern still. You may as well polish the crank as best u can and put in the new bearings
Throttle cables ftw
Reply #46April 28, 2013, 11:46:45 am
Gizmoman
  • 1301
« Reply #46 on: April 28, 2013, 11:46:45 am »
Thanks,
The crank is in, torqued, and sittin' on new bearings after I finally got the full and correct set - spins dandy. The journals were perfect.
Too bad I didn't just keep a build thread going when I started over a year ago - I've got bits scattered all over this forum ;D
