Author Topic: US to CE2 electrical  (Read 3430 times)
March 03, 2013, 03:21:53 am
jhax
  • 328
« on: March 03, 2013, 03:21:53 am »
Hello,
So im trying to draw up a diagram for my CE2 conversion from the US electrical system. I am looking specifically at the water separator wiring (http://www.autolib.diakom.ru/CAR/Volkswagen/1987/Golf/WIRING%20DIAGRAMS/6510.pdf). I am trying to figure out how to wire this up to the M connector in the CE2 fusebox. The CE2 (http://www.a2resource.com/electrical/CE2.html) does not mention anything about the ground wire or the YEL/WHT wire that goes into fuse 3. From what I can gather, the BRN/BLK wire goes to M/04 connector. What about the other two aforementioned wires?
Thank You,
Justin
Reply #1March 03, 2013, 04:17:27 am
bbob203
  • 1789
Re: US to CE2 electrical
« Reply #1 on: March 03, 2013, 04:17:27 am »
I say don't even use a water seperator. most people hete delete them anyway.
92 Passat wagon M-TDi
03 Jetta wagon TDi
VE Timing tools for rent
Reply #2March 03, 2013, 07:10:06 am
« Reply #2 on: March 03, 2013, 07:10:06 am »
i agree delete the seperator and u just solved 2 problems for your self (potential fuel leaks and having to wire it in)
Reply #3March 03, 2013, 08:58:41 am
92EcoDiesel Jetta
« Reply #3 on: March 03, 2013, 08:58:41 am »
Hello,
Thank You,
Justin
Justin,
Kudos for trying to get your water separator sensor to work. It may save your IP someday. The ground wire just connect it to ground anywhere. The fuse 3 wire is the power for the water sensor which is a 3 terminal solid state device (per stamping on the sensor) and per my Bentely goes to M/5. The remaining wire from the sensor goes to M/4 which is the L terminal on the glow relay. I'll post a pic of the Bentley shortly.
I intend getting my water in fuel warning working also. My water separator has a small crack and lets air and has been removed. I may use a mason jar or something else and make my own separator with my own sensor.
Reply #4March 03, 2013, 08:59:48 am
92EcoDiesel Jetta
« Reply #4 on: March 03, 2013, 08:59:48 am »
Reply #5March 03, 2013, 04:54:43 pm
jhax
  • 328
« Reply #5 on: March 03, 2013, 04:54:43 pm »
and this is for ce2 I assume? If so awesome! Trust me guys I would delete it but at the same time I plan on going alh in the future and im sure it would be a good thing to keep.
Reply #6March 03, 2013, 05:16:06 pm
« Reply #6 on: March 03, 2013, 05:16:06 pm »
Having a water detection system is good, just not an old timebomb of a detection system. It will strand you at the worst time.
Someone mentioned the Racor setup, I'd suggest checking that out.
Reply #7March 03, 2013, 07:09:47 pm
jhax
  • 328
« Reply #7 on: March 03, 2013, 07:09:47 pm »
I'll look into that, thank you. If any of you hear of anyone selling a ce2 golf body harness less the fuseblock let me know
Reply #8March 03, 2013, 11:35:16 pm
jhax
  • 328
« Reply #8 on: March 03, 2013, 11:35:16 pm »
Okay so based on the CE2 diagram above and the US spec site I linked here is what I came up with
http://sdrv.ms/13AXnZ6
