Author Topic: WTB MK2 hand brake lever 357711307A  (Read 5036 times)
March 02, 2013, 09:13:08 am
92EcoDiesel Jetta
« on: March 02, 2013, 09:13:08 am »
I need a MK2 hand brake lever 357711307A. The teeth on mine (92 Jetta Ecodoesel) are mangled. I can probably fix it with grinding/ filing but it'd be easier by replacing it with a good used one.
Reply #1March 02, 2013, 09:33:36 am
Re: WTB MK2 hand brake lever 357711307A
« Reply #1 on: March 02, 2013, 09:33:36 am »
same one on 88+ mk2-99.5 mk4.. bolts to floor with 2 nuts and studs in tunnel.. at least it bolts in...
Reply #2March 02, 2013, 10:53:59 am
92EcoDiesel Jetta
« Reply #2 on: March 02, 2013, 10:53:59 am »
Thanks! Good to know. I may not need it though. Took a Dremel with a diamond bit (it's hardened and a file just glances off) and sharpened the rounded/ chewed up pawl, which was the cause of the parking brake lever popping. It looks good now and seats well in the teeth. Real test is whether it holds when installed.
I ignored the parking brakes with a frozen parking brake cable for way too long, which caused the lever to pull unevenly and the pawl to run off center relative to the teeth thus chewing it up.  It popped a few months ago, the only time I forgot to leave it in gear while I ran into a store double parked and the car rolled and dented the door of a van- my only "accident" in many many years.
Don't procrastinate like me and replace any frozen parking brake cables!
« Last Edit: March 02, 2013, 10:57:27 am by 92EcoDiesel Jetta »
Reply #3March 02, 2013, 12:20:32 pm
92EcoDiesel Jetta
« Reply #3 on: March 02, 2013, 12:20:32 pm »
Installed it and it works fine! Don't need a replacement anymore.
Reply #4November 27, 2014, 01:00:02 pm
92EcoDiesel Jetta
« Reply #4 on: November 27, 2014, 01:00:02 pm »
It worked fine until a week ago and my parking brake lever is popping off again. Anyone have a good used one please pm me with price + shipping.
Reply #5November 30, 2014, 10:59:47 pm
masterbeavis
  • 88
« Reply #5 on: November 30, 2014, 10:59:47 pm »
A friend is parting an 88 golf, I can take pics and see if if is what you need.  Probably $20 plus the ride.
81 Caddy Diesel, 84 Jetta Diesel, 98 Jetta GLS, 99 Jetta GLX,, 95 Golf.
Reply #6December 01, 2014, 09:01:42 pm
masterbeavis
  • 88
« Reply #6 on: December 01, 2014, 09:01:42 pm »
my buddies has 171711305B stamped into the handle.  I have pics I can text you.  916 257 six7six4
Reply #7December 01, 2014, 09:36:06 pm
92EcoDiesel Jetta
« Reply #7 on: December 01, 2014, 09:36:06 pm »
Txted 916 257 6764 . Reply was "wrong number"
Reply #8December 01, 2014, 10:19:30 pm
masterbeavis
  • 88
« Reply #8 on: December 01, 2014, 10:19:30 pm »
im sorry, I transposed a  number and did not proof my message properly.  916 275 six7six4
Reply #9December 03, 2014, 03:46:27 pm
92EcoDiesel Jetta
« Reply #9 on: December 03, 2014, 03:46:27 pm »
Your's will not fit.
This is what it looks like. I sharpened  the pawl and teeth again with a Dremel and adjusted the lever so it engages higher (on better condition teeth) and it does not slip anymore. How long will it last is the question. If anyone have one of these please pm me.
