Author Topic: Rev counter wiring - not the usual or FAQ!  (Read 4157 times)
February 26, 2013, 03:56:29 am
Adamksi
« on: February 26, 2013, 03:56:29 am »
Quick one really. I have a set of GTD clocks with rev counter, from my old GTD working fine. I've done an MTDi conversion into a new car and some of the wiring is GTI so I've lost the W terminal wire. Basically, where does this need to connect to on the fusebox and/or clocks? I know to run it from W terminal on the alternator but stumped where the other end goes.
thanks!
Reply #1February 26, 2013, 10:51:22 am
92EcoDiesel Jetta
Re: Rev counter wiring - not the usual or FAQ!
« Reply #1 on: February 26, 2013, 10:51:22 am »
If you have MK2 wiring, the w terminal wiring should be there, going to the correct pin in the 28 pin cluster connector.
Reply #2February 27, 2013, 07:51:13 am
Adamksi
« Reply #2 on: February 27, 2013, 07:51:13 am »
any idea what pin it is?
I've got a GTD engine loom but GTI alternator and dash loom!
Reply #3February 27, 2013, 08:10:23 am
92EcoDiesel Jetta
« Reply #3 on: February 27, 2013, 08:10:23 am »
If it's MK2 wiring , it's T28/10
