Author Topic: Time to start assembling 1.5 TD / 1.9L Franken Diesel.  (Read 110398 times)
Reply #345March 22, 2014, 09:58:12 am
Jetmugg
  • 530
Re: Time to start assembling 1.5 TD / 1.9L Franken Diesel.
« Reply #345 on: March 22, 2014, 09:58:12 am »
That's my guess, too.
From a standing start, 1st gear will "wrap out" very quickly, probably within the first 100 feet or so.  2nd gear won't take much longer.  My goal is to wind 3rd gear up to my comfortable limit of rpms before shifting into 4th.  I don't want to "lug" the engine in 4th.  Once I'm in 4th and get up around 4000 rpm or so, I will adjust the boost controller to give full boost.
At that point, I'll sneak some peeks at the EGT gauge and manage the throttle accordingly, keeping the truck pointed in the right direction.
If everything goes as expected, my comfort level with EGT may be the limiting factor.  I just don't have a good idea of a safe upper limit for EGT.
I'm trying to save some pennies for a Snow Performance water injection setup to mitigate the EGT's a bit.
Steve.
Reply #346March 22, 2014, 10:46:17 am
« Reply #346 on: March 22, 2014, 10:46:17 am »
more boost will help keep egts down, so u may want to set it and forget it, but i think in a mile on pavement you will easily reach terminal velocity, i would think in a quarter mile you can already reach 90-100mph, so a whole mile should be easy to hit your max.
Reply #347June 07, 2014, 04:50:15 pm
« Reply #347 on: June 07, 2014, 04:50:15 pm »
I hope that he has some news to bump one of his threads soon
Reply #348June 08, 2014, 04:20:16 pm
Jetmugg
  • 530
« Reply #348 on: June 08, 2014, 04:20:16 pm »
We are the new ECTA recordholders!
123mph and some change.  We had a great time, and I had the chance to meet TheMan53 and CSMP5 at the meet.
Thank you very much for all the support and encouragement guys.
I'll have pics, video, and stories to share later.  I just got home and will spend some time with family now.
Steve.
Reply #349June 08, 2014, 07:25:30 pm
« Reply #349 on: June 08, 2014, 07:25:30 pm »
I knew you had it, but didn't want to let the cat out of the bag. I wish you guys didn't have it all under control as I was prepared to wrench.
So now that you believe me that it will go that fast, what do you think you will do in Utah. You will have longer to wind it up and run different tires/trans if needed.
Have fun with the family and let us know. Great job
Reply #350June 08, 2014, 10:26:21 pm
Alcaid
  • 549
« Reply #350 on: June 08, 2014, 10:26:21 pm »
Congrats Jetmugg! :)
'10 VW Passat 1.6TDI Highline
Reply #351June 09, 2014, 03:15:52 am
carrizog60
  • 978
« Reply #351 on: June 09, 2014, 03:15:52 am »
congrats!
now time for a tdi gearbox conversion  ;D
Portugal
Reply #352June 09, 2014, 06:51:51 am
Alcaid
  • 549
« Reply #352 on: June 09, 2014, 06:51:51 am »
A CTN gearbox would be nice, together with a properly matched Holset turbo off course ;)
Dieselmeken just build me a new pump for my 1.6TTD, over 200cc of fuel, yours was something like 90-100cc? Time to step up and crush your own record :)
Reply #353June 09, 2014, 07:29:49 am
« Reply #353 on: June 09, 2014, 07:29:49 am »
How were you getting a hold of Dieselmekken? When I was trying to source my pump I emailed him several times and never got an answer :-(
Reply #354June 09, 2014, 07:49:34 am
« Reply #354 on: June 09, 2014, 07:49:34 am »
Same, I told him to build me an 11mm pump for my 1.6...no response
Reply #355June 09, 2014, 09:18:24 am
Alcaid
  • 549
« Reply #355 on: June 09, 2014, 09:18:24 am »
[email protected] and he is also on facebook, this is the second pump he built for me, found out the 11mm 130cc didn't deliever enough for my goals ;)
Reply #356June 09, 2014, 10:58:20 am
Jetmugg
  • 530
« Reply #356 on: June 09, 2014, 10:58:20 am »
The existing record at Bonneville is 106.xxx mph.  My first goal is to be competitive against that record.  I need to put 2 consecutive passes together in excess of the existing record to become the new SCTA recordholder.  That is my first goal.
Assuming I can do that, then I will "let it all hang out" at SpeedWeek to see how much I can wring from the existing setup.  I want to get everything I can out of the current setup before changing anything.
I have always said that I don't want to blow it up in Ohio or on the first day of SpeedWeek, but I don't really care if I blow it up on the last day of SpeedWeek if I haven't set a record yet.
Looking ahead, there are plenty of paths to take, ranging from additional pump, turbo, and cylinder head work on the 1.5 engine, to building a 2.0 class engine, to putting a gasoline burning (gasp) engine in the truck to chase some of those records.
Goran at Dieselmeken has been great to work with, as has Giles.  Giles sent me one of his cams, and Goran did the pump work.  Goran is very easy to get ahold of through FaceBook and via email from my perspective.  He seems to be a very busy guy, but has offered superb customer service to me.
He will most likely be the guy to build the next pump I need, no matter what diesel engine it's for.
Steve.
Reply #357June 09, 2014, 12:43:20 pm
Jetmugg
  • 530
« Reply #357 on: June 09, 2014, 12:43:20 pm »
Reply #358June 09, 2014, 02:00:21 pm
« Reply #358 on: June 09, 2014, 02:00:21 pm »
I love the faint reflection of the puff of smoke from your stack when you shift - you can just barely see it against the orange glossy instrument panel. :D
Reply #359June 09, 2014, 08:11:22 pm
« Reply #359 on: June 09, 2014, 08:11:22 pm »
Where the EGT better after turning up the boost?
