Author Topic: Opinions on Hose clamp egt probe  (Read 3590 times)
February 17, 2013, 09:08:14 pm
bbob203
  • 1789
« on: February 17, 2013, 09:08:14 pm »
got this on a trade worth using?
92 Passat wagon M-TDi
03 Jetta wagon TDi
VE Timing tools for rent
Reply #1February 17, 2013, 11:42:31 pm
mystery3
  • 774
Re: Opinions on Hose clamp egt probe
« Reply #1 on: February 17, 2013, 11:42:31 pm »
I've never seen one or heard of problems but it doesn't look like a good setup from an exhaust leak standpoint.
Reply #2February 18, 2013, 01:55:09 am
Blownoiler
  • 18
« Reply #2 on: February 18, 2013, 01:55:09 am »
The probe is supposed to have at least 2/3rds of its length in the exhaust flow according to the instructions that I got with a similar looking probe, I'm not sure why, it could be for fast response or for a more accurate reading. If you do use it then think about mounting the probe on the outside of a bend rather than a low-flow area
One can never have too much power!
Reply #3February 18, 2013, 03:05:00 am
« Reply #3 on: February 18, 2013, 03:05:00 am »
Planes use em like that,  and if your hole is anywhere near tight, it will soot itself sealed in no time.
Reply #4February 18, 2013, 06:00:43 am
justiz00
  • 54
« Reply #4 on: February 18, 2013, 06:00:43 am »
My isspro is like that. It came with a lead looking soft collar that goes between the pipe and the hose clamp around the probe to seal. Works well in the cast downpipe elbow.
Reply #5February 18, 2013, 06:21:04 am
« Reply #5 on: February 18, 2013, 06:21:04 am »
That thing looks pretty thick. The tests done on the thick ones is they react very slow. Also, we have been over this here a million times, but the place to put it is preturbo. I think it might be hard to get that in the exhaust manifold preturbo.
Reply #6February 18, 2013, 02:36:54 pm
« Reply #6 on: February 18, 2013, 02:36:54 pm »
yea we went to summit and got screw in kind... picked up a front seal carrier as after removing crank bolt found fun suprise.. he got pics.. but pln to have the m sittin in his b3 by time he takes off tomarro wnight...
lucas... he needs his mk2 tranny rebuilt... got bad pinion/diff bearing... howles real bad.. and i ask him.. he like what noise.. :D vid #2 commin.. LOL..
Reply #7February 19, 2013, 08:52:36 am
  • 5104
« Reply #7 on: February 19, 2013, 08:52:36 am »
hose clamp style would be good for an na install i'd think.  but whats the point on na haha.
Reply #8February 19, 2013, 02:45:03 pm
« Reply #8 on: February 19, 2013, 02:45:03 pm »
Fuel economy, overheat prevention, and diagnostics.
