Author Topic: A few wiring bugs  (Read 5636 times)
February 13, 2013, 08:33:15 pm
bbob203
  • 1789
A few wiring bugs
« on: February 13, 2013, 08:33:15 pm »
#1 Glow plug relay is ticking intermittently thought it had a pattern of when it would occur but now no idea. Only time it definitely does it is on an immediate restart after a long haul. Just on its way out? I dropped down the fuse box and nothing looked out of the ordinary in that department.
#2 I discovered a pretty toasty bown wire on terminal f connector some kind of ground? Any idea where it goes?
http://www.a2resource.com/electrical/CE2.html
92 Passat wagon M-TDi
03 Jetta wagon TDi
VE Timing tools for rent
Reply #1February 13, 2013, 08:42:55 pm
Re: A few wiring bugs
« Reply #1 on: February 13, 2013, 08:42:55 pm »
Do you know the age of the relay? Remove it and test it.
There should be two brown wires in the F connector and they are both to the main fuse box grounds internally of the fusebox  which should go directly to the battery negative.
Reply #2February 14, 2013, 04:21:01 am
bbob203
  • 1789
« Reply #2 on: February 14, 2013, 04:21:01 am »
Could be stock relay.. Only 1 brown wire on me battery.
03 Jetta wagon TDi
Reply #3February 14, 2013, 06:55:46 am
« Reply #3 on: February 14, 2013, 06:55:46 am »
The way I read the Bentley, the brown wires on bus #31 go to Chassis-ground.
Something drew heavy current through there... who knows when... any known short  (GP relay, Headlights, Cig lighter, Fresh air fan)?
Reply #4February 14, 2013, 07:04:28 am
bbob203
  • 1789
« Reply #4 on: February 14, 2013, 07:04:28 am »
That wire was at one point poorly connected to the negative battery terminal it has since been fixed the whole casing on it looks like a kraft single in the microwave though bubly melty and crispy.
03 Jetta wagon TDi
Reply #5February 14, 2013, 07:21:42 am
« Reply #5 on: February 14, 2013, 07:21:42 am »
I'd be looking for other wires with similar issues, that current came from somewhere.
Reply #6February 14, 2013, 08:38:17 am
bbob203
  • 1789
« Reply #6 on: February 14, 2013, 08:38:17 am »
I think it was from prolonged cranking when I was having injection pump issues.
new relay is in so hopefully that will cure my tick tick tick
03 Jetta wagon TDi
Reply #7February 14, 2013, 03:26:48 pm
bbob203
  • 1789
« Reply #7 on: February 14, 2013, 03:26:48 pm »
glow plug relay still clicking after new installed ??? ???
03 Jetta wagon TDi
Reply #8February 14, 2013, 03:35:11 pm
« Reply #8 on: February 14, 2013, 03:35:11 pm »
Give up on stock system. Install standalone glow plug system and be better off in life. ;)
Glows will get higher voltage and amperage, if it fails its right there in the open to diagnose, parts are all cheaper than one glow relay lol.
